Author Topic: Internal pump pressure  (Read 11452 times)
May 10, 2012, 03:05:43 pm
Gator79
  • 53
« on: May 10, 2012, 03:05:43 pm »
I want to check internal pump pressure on my rabbit td, only thing I can find on here is tapping into the out bolt or the stand off neither of witch I want to do. Can I splice into the return line right after the out bolt or will that not give an accurate reading or evan work at all? If there's a better way please let me know thanks.
Reply #1May 10, 2012, 03:31:14 pm
92EcoDiesel Jetta
Re: Internal pump pressure
« Reply #1 on: May 10, 2012, 03:31:14 pm »
Return line gives external IP fuel return pressure- not what you're looking for. If you don't want to do the two you mentioned, another option is to drill a hole in the IP cover and put a barb there.  ;D
Reply #2May 10, 2012, 03:39:19 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #2 on: May 10, 2012, 03:39:19 pm »
No, the holes in the "out" banjo bolt are tiny, which won't give you an accurate reading of the internal pump pressure unless you drill and tap the end of the bolt, which is directly connected to the internal pressure of the pump.
If you're hesitant to modify the bolt itself, you could (assuming you have access to some basic tools) make a new, custom stand-off which has a fitting for a pressure line to a gauge using stuff that should be readily available at a good hardware store. That's probably what I'll end up doing when I get around to checking my IP pressure.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #3May 10, 2012, 04:23:22 pm
92EcoDiesel Jetta
« Reply #3 on: May 10, 2012, 04:23:22 pm »
Another option is rent it from me. I have a spare out pedestal, drilled and tapped for a pressure gauge.
Reply #4May 14, 2012, 12:42:16 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: May 14, 2012, 12:42:16 pm »
Or google the late "Hagar transfer pressure smileage" and you should find lots of info, dont use his transfer pressures unless yours is an early Rabbit.
Reply #5October 02, 2013, 03:34:56 am
vako
  • 187
« Reply #5 on: October 02, 2013, 03:34:56 am »
i have one odd question about internal pump pressure. is it possible tu meaure appproximate internal pressure according to overflow quantity?     in this document there are some figures about overflow values.... and i thought that measuring it will help me a bit.   correct me if i'm wrong  ;D      my problem is that after heating up well car starts to twitch on light throttle. as soon as i push it hard twitching goes away. so i'm trying to find what could be the problem
cheers vako (y)
Reply #6October 02, 2013, 09:01:29 am
« Reply #6 on: October 02, 2013, 09:01:29 am »
Hagar had quantity at idle figured out as well.  Something like a liter in 90 seconds.  Not sure on the liter part but go look.  His premise was if it is proper at idle then the rest would take care of itself.  If you didn't get the proper quantity then you would tap down on the regulator in the front of the IP and adjust it.  Tap easy it only needs to move a tiny bit to change the internal pressure.
Reply #7October 02, 2013, 09:07:37 am
vako
  • 187
« Reply #7 on: October 02, 2013, 09:07:37 am »
i've got one more question  ??? where car i find hagar info?    i've searched teh web but some links are dead and i was not able to find anything :(
Reply #8October 02, 2013, 11:20:51 am
mtrans
  • 308
« Reply #8 on: October 02, 2013, 11:20:51 am »
X2,work for my google.
or internal injection pump pressure.
« Last Edit: October 02, 2013, 11:24:05 am by mtrans »
I`ll improve my English
Reply #9October 02, 2013, 12:12:07 pm
vako
  • 187
« Reply #9 on: October 02, 2013, 12:12:07 pm »
the most informative thread i found was this http://www.vwdieselparts.com/forum/viewtopic.php?t=5936&start=0  and read the whole topic.. but still there are no overflow values :(
i will have to wait for the sensor for 2-3 weeks (to be shipped from usa,  i live in georgia country) so monitoring IP internal pressure with the pump is a bit of an issue for me :D
Reply #10October 02, 2013, 03:08:06 pm
smutts
  • 720
« Reply #10 on: October 02, 2013, 03:08:06 pm »
I think this might has been the link, but it is a long one. Unfortunately the writer is no longer with us.
http://www.vwdieselparts.com/forum/viewtopic.php?f=8&t=4868
A good rummage in the scrapyard should find a Bosch pump with a suitable pedestal. It's not just a VW thingy.
I would be most leery on the "driller killer" approach on a working pump, unless you want a hole in a knackered pump.
« Last Edit: October 02, 2013, 03:16:39 pm by smutts »
Reply #11October 02, 2013, 03:20:16 pm
« Reply #11 on: October 02, 2013, 03:20:16 pm »
625ml/90 seconds...  at idle, I believe.
If you google "Going back in the thread, Hagar said" (with quotes, for the phrase) you can see some discussion.
Reply #12October 02, 2013, 03:27:29 pm
« Reply #12 on: October 02, 2013, 03:27:29 pm »
Smutts has the link proper.  Just search for some terms mentioned here and you will find it.
I went looking for the summary sheet I started to build one time as I was reading the thread and can't find it on the computer now.  Could be on the spare desktop one.  The 625 ml looks better to me than my original 1 liter measure.  Thanks for the correction TylerD.
Reply #13October 03, 2013, 12:59:03 am
mtrans
  • 308
« Reply #13 on: October 03, 2013, 12:59:03 am »
Reply #14October 03, 2013, 01:46:04 am
Toby
  • 728
« Reply #14 on: October 03, 2013, 01:46:04 am »
That won't work because the "tiny hole" is in the end of the bolt is a metering oriface and that end screws into the pump. Drilling and tapping the head of the bolt is still checking external pressure, not internal. Opening up the "Out" bolt oriface messes up the internal pressure.
