Author Topic: Hanging rpm after hardline change - IDI  (Read 5607 times)
April 24, 2012, 12:43:15 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« on: April 24, 2012, 12:43:15 am »
One of the hardlines sprung a leak so I got replacements from prothe. I had to bend them slightly to make them fit my 1.6td pump on an aaz. I also redid the timing. I don't have any tools for timing so I just rotated the pump by ear until the smoke faded and the knock was only audible on a pulled out cold start lever. Now when I actuate the throttle lever the rpm will hang for a long 2 seconds...
Any ideas?
Ed
Reply #1April 24, 2012, 07:13:13 am
Re: Hanging rpm after hardline change - IDI
« Reply #1 on: April 24, 2012, 07:13:13 am »
I wouldn't have pulled out the cold start lever when trying to time it by ear.  And it sounds like you need to back off the smoke screw and maybe then adjust the idle back up with the stop that touches the accel lever.
Reply #2April 24, 2012, 07:22:57 am
« Reply #2 on: April 24, 2012, 07:22:57 am »
ID of the lines could be off some??? You could be throwing more or less to it than you were before needing to chance advance??? all guesses to this, shouldn't do that unless your fuel screw was messed with. Could it have been bumped?
Reply #3April 24, 2012, 09:55:47 am
Smokey Eddy
  • 3468
« Reply #3 on: April 24, 2012, 09:55:47 am »
The fuel screw is really locked down but it is turned in really far. Ill try backing it off.
For what its worth, I didn't time the pump with the lever out I merely meant to point out I timed so it only clacked with the lever out.
Ed
Reply #4April 24, 2012, 12:21:09 pm
« Reply #4 on: April 24, 2012, 12:21:09 pm »
Pulling the cold start lever only adds a few degrees of advance to the system.  2.5 I think, so if you're clacking at that point I would wonder how it is going to do as you cruise down the road at 50.  There you add about 12 degrees to it if your IP internal pressure is correctly set to give you 74 Lbs at that RPM.
Maybe that bears looking into.  Amount of advance if clacking at idle versus no clack.  You would need a timing gauge to know your values as you have it set right now.  Since you don't have one any one near you that you could measure it?
Reply #5April 24, 2012, 12:36:58 pm
Smokey Eddy
  • 3468
« Reply #5 on: April 24, 2012, 12:36:58 pm »
I'm about to move back to near Vancouver today so maybe. We will see how the 4 hour drive goes I guess.
Ed
Reply #6April 24, 2012, 02:45:33 pm
Trips_B
  • 57
« Reply #6 on: April 24, 2012, 02:45:33 pm »
Well your welcome to stop by my place in surrey,  I have a dial gauge
Reply #7April 24, 2012, 04:54:59 pm
« Reply #7 on: April 24, 2012, 04:54:59 pm »
pretty sure the cold start lever advances the timing +6*
Reply #8April 24, 2012, 05:24:08 pm
Smokey Eddy
  • 3468
« Reply #8 on: April 24, 2012, 05:24:08 pm »
I advanced the timing some more and it went away mostly.
Ed
Reply #9April 24, 2012, 07:50:37 pm
maxfax
  • 2126
« Reply #9 on: April 24, 2012, 07:50:37 pm »
I ran into the opposite once upon a time..  Replaced the hard lines (with used OE ones no less) Clacked like a Mofo till I toyed with the timing...
Reply #10April 28, 2012, 12:06:11 pm
Smokey Eddy
  • 3468
« Reply #10 on: April 28, 2012, 12:06:11 pm »
Yes I found the same. Clacked hardcore and burned grey/white + hanging rpm until I really fiddled with the timing a bunch.
Ed
