Author Topic: Not so Good Vibrations  (Read 8171 times)
April 15, 2012, 07:34:50 pm
« on: April 15, 2012, 07:34:50 pm »
I don't care what the Beach Boys say if my engine is still vibrating after all the reposition and replacing of the motor mounts it is not a good thing.
So where do I go next?  Would excessive timing be the problem?  It starts super quick and revs a little low at first but then picks up after about 15 seconds.  I have a pull cable on the throttle and can use that as a high idle set.  The cold start lever is for timing only on this 1981.
Seems as I move down the road I get a pattern to the vibration at 27 35 56 but not bad in between.  If I drop it down from fifth to fourth at 56 it smooths out some as well.
I have a pressure gauge on the IP and I do pick up pressure in fourth with the higher RPMs.  Goes fro 75 up to 82.5 on the gauge.
Mileage is down from previous tanks as well.  Can't tell by cracking an injector nut that one cyclinder is off compared to the others but that is what I think might be happening.  I don't have a pop tester so I would need to do something with the IP and the lines turned up with the injector on it.  Messy that is.
Let me know what you would look for as a source of the problem.  I was rolling at 60 and turned off the engine to see if that might make a difference.  Smooth as silk without it on.  Had it in neutral with the clutch engaged trying to eliminate the transmission and axles.  Seems engine related for sure.
Put a thinking cap on it.  DAS
Reply #1April 15, 2012, 07:41:22 pm
wdkingery
  • 494
Re: Not so Good Vibrations
« Reply #1 on: April 15, 2012, 07:41:22 pm »
Just how much vibration are we talking here? Since I put that one odd connecting rod in I had a new rear view mirror vibration but minor.
Is this shaking yer dash out?
Are you in a position to rering? It wasn't too bad. And helped loads. Just make sure to clean the dog nuts out of them grooves.
Is the only problem the vibrations? Or does it appear like it could damage the car?
Reply #2April 15, 2012, 07:45:52 pm
billybobf
  • 318
    89 golf 1.8 digi, 1.6 na in pieces in the shop
« Reply #2 on: April 15, 2012, 07:45:52 pm »
I have a piston ring cleaner hear, and I plan on making a pop tester yesterday, but could make it tomorrow. a non fluid gauge tho, just a 2500 psi weld tank gauge and a floor jack, cant to a leakdown I don think cuz I would make my first on with a junk jack.
have spare hardlines, Have an adapter I can use, and have the jack and gauge. just gotta put it together, I do have a 220v mig welder too
Reply #3April 15, 2012, 08:20:36 pm
« Reply #3 on: April 15, 2012, 08:20:36 pm »
I should tell you the shake is minor vibrations.  Yes, fusses up the review mirror headlights from the cars behind me.  Side mirrors steady as a rock.  Also I can feel the buzz in the accel pedal.  Steering wheel shakes at idle a tiny bit.  Once I give it just a touch on the pedal that clears up.
That is why I chased around on the motor mounts for so long.
BillyBob, get a working pop tester up and going and I might just come see you.  Only an hour away.  Less if no tourist on the road.  That won't last long now will it.
Reply #4April 17, 2012, 08:07:01 pm
« Reply #4 on: April 17, 2012, 08:07:01 pm »
I can feel the vibes in my butt.  Is this engine or part of it out of balance?  I haven't removed anything that I can think of to make it do that.
Reply #5April 18, 2012, 08:31:38 pm
« Reply #5 on: April 18, 2012, 08:31:38 pm »
crappy exhaust hangers/mounts will transmit LOTS of vibrations thru the body.
Reply #6April 18, 2012, 08:38:16 pm
« Reply #6 on: April 18, 2012, 08:38:16 pm »
I was wondering about that as I noticed a louder tune coming from it lately.  I have been running Biodiesel B100 and it takes more foot to make it go.  MPG dropped too from 46s to 41-2.  With the shakes the doughnut ring may now be worn and leaking.  At least that is my thought on it.
Hoping for no rain this weekend.  Like today   wow, real sunshine requiring shades to drive.  What's with that?
Reply #7April 18, 2012, 08:57:35 pm
« Reply #7 on: April 18, 2012, 08:57:35 pm »
doughnut ring?
the actual rubber exhaust hangers?
or the graphite/metal wire sealing ring for the toilet bowl manifold?
Reply #8April 18, 2012, 09:10:08 pm
« Reply #8 on: April 18, 2012, 09:10:08 pm »
The metal toilet bowl one.
Reply #9April 19, 2012, 05:00:07 pm
« Reply #9 on: April 19, 2012, 05:00:07 pm »
thats not what i was talking about..
i was tanking about your RUBBER EXHAUST HANGERS being bad..
the toilet bowl gasket, i cant see that transmitting vibrations to the car..
Reply #10April 19, 2012, 08:25:27 pm
« Reply #10 on: April 19, 2012, 08:25:27 pm »
I was thinking the toilet bowl gasket was worn by the engine vibrations and was now leaking exhaust and sounding louder.
I will give the hangers a going over but I think they were all in pretty good shape a bit back when I was doing a transmission linkage fix.
Never hurts to check twice.  Lots of road hazards out there.
Reply #11April 19, 2012, 08:29:08 pm
billybobf
  • 318
« Reply #11 on: April 19, 2012, 08:29:08 pm »
Ok, got the line, got the gauge, got the fitting, got the jack. now all i have to do is combine the items... and check my injectors out
Reply #12April 20, 2012, 09:56:58 pm
« Reply #12 on: April 20, 2012, 09:56:58 pm »
I think it is just the way of the Mk1 body style my friend.. I have had the same car since 2007, and in that time I have had 4-5 motors in it and just as many transmissions. All of them, gas or diesel have vibrated at a certain RPM to make my roof sheet metal vibrate like no other.. All with obvious different motor mount alignments, exhaust or no exhaust, old motor mounts to new..
Mk1 will always vibrate lol.
Reply #13April 20, 2012, 10:10:26 pm
billybobf
  • 318
« Reply #13 on: April 20, 2012, 10:10:26 pm »
but never a bad thing to test old parts if the option is available
Reply #14April 21, 2012, 08:39:12 am
« Reply #14 on: April 21, 2012, 08:39:12 am »
OK, destiny has it that we will be buzzing down the road then.  Billybobf, have you constructed the pop tester yet?  It would be easier for me to drop by on a Friday afternoon and pull the injectors to test at your place on the way home then to pull them up here and try to get them to the shop.
Going to lay on the ground a bit today and double check the exhaust hangers and such.  Might pop the big C clamps off if I have my 2 inch muffler clamp in the tool box to put them back on.
Thanks guys, not really what I cared to hear but at least I am no longer wondering about something being a miss with the engine.  Which I couldn't fathom as it does test well and the mileage is low, 130K just rolled it over.
