Author Topic: Setting timing on engine stand  (Read 3116 times)
December 07, 2011, 08:37:24 pm
dieselherb1
  • 354
« on: December 07, 2011, 08:37:24 pm »
I have a engine on a stand without flywheel(stand bolts to block, no room for flywheel) or harmonic balancer like to time engine. Have it at top dead center. Any easy way to timing it?
Herb
Reply #1December 07, 2011, 11:26:13 pm
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
Re: Setting timing on engine stand
« Reply #1 on: December 07, 2011, 11:26:13 pm »
You need the fly wheel. Unless you can get it to top dead center with out it. (Pull injector use feeler gauge...)
Reply #2December 07, 2011, 11:36:26 pm
« Reply #2 on: December 07, 2011, 11:36:26 pm »
using the nipple on the crank sprocket... will be in 7"oclock position with the 8mm threads pointed directly at the oil pan bolt at 6"oclock.. is pretty damb close to TDC...... IF the crank sprocket original and not been modded..
id try it then when you pull it off.. double check tdc and cam to be 100% but i think you will find it pretty dead nutz...
Reply #3December 08, 2011, 07:26:56 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #3 on: December 08, 2011, 07:26:56 am »
Leave the oil pan off and check the TDC of #1 like that. I always put the oil pan on last anyways. Helps out alot
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #4December 08, 2011, 08:01:01 am
rodpaslow
  • 670
« Reply #4 on: December 08, 2011, 08:01:01 am »
It's way easy to time now that you have it at top dead center.  You need a reference to get it back to TDC because you need to rotate the engine backward slightly to time the inj pump and then rotate it back to TDC.   So mark some kind of reference you know is good, or as above you can use the #1 rod cap with a dial gauge to get #1 at TDC.
Install inj pump in a good starting point, install it's lock, install the lock on the cam with the pulley loose.  Install the timing belt with engine at TDC and tighten belt. Take cam lock out and inj pump lock out, install the dial gauge in the end of the inj. pump rotate the engine backwards until the dial stops moving, 0 the dial and rotate the engine forwards to TDC.  Read the dial and adjust inj. pump accordingly! Done!
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #5December 08, 2011, 12:50:52 pm
rodpaslow
  • 670
« Reply #5 on: December 08, 2011, 12:50:52 pm »
your correct! Thanks!
Reply #6December 08, 2011, 07:04:31 pm
Mark(The Miser)UK
  • 1557
« Reply #6 on: December 08, 2011, 07:04:31 pm »
Only nip up the cam with the lock in, else you'll join the crowd who have busted cam slots.
Remove pump pin and cam lock then tighten up with car in gear.
Ideally make up a Y'  wrench to hold cam pulley.
Mark-The-Miser-UK
Reply #7December 08, 2011, 08:46:45 pm
« Reply #7 on: December 08, 2011, 08:46:45 pm »
Mark, engine is on stand.  Can't do the in gear thing yet.
Reply #8December 09, 2011, 01:43:15 am
Mark(The Miser)UK
  • 1557
« Reply #8 on: December 09, 2011, 01:43:15 am »
Get a bigger stand that allows the car to be attached next time then ;D
No problem still proceed by nipping up with locks in, a few lb ft Then remove them and then tighten by  tapping a spanner on the cam bolt with a hammer.
Later do a torqued reading in the car if neccessary for your stress relief. If engine not going back in  car, put a note on the cam pulley.
I only tap them these days as I feel comfortable with it, but I used to torque them up to check. I tended to be a little under torque, but as I always 'prepped' the tapered joint, I soon became confident.
I suppose an air hammer would work if settings were known.
Mark-The-Miser-UK
