Author Topic: unknown IP settings??  (Read 9784 times)
November 03, 2011, 08:08:21 am
guy plain
  • 121
« on: November 03, 2011, 08:08:21 am »
 i put a pump on my 1.6 td that was a spare...looks like its been played with....... i do have more power...less smoke but its not running right... i was wondering if any has any idea on  base settings to go from... i dont really know the history on this pump but it does look to be in better condition than my old one and it doesnt leak lol
  any suggestions would be appreciated...thank you
Reply #1November 03, 2011, 11:26:35 am
maxfax
  • 2126
Re: unknown IP settings??
« Reply #1 on: November 03, 2011, 11:26:35 am »
First of all, what's not right about how it's running??? The lack of smoke with good power tells me that the fuel screw setting is in the ball park..
Reply #2November 03, 2011, 01:56:16 pm
guy plain
  • 121
« Reply #2 on: November 03, 2011, 01:56:16 pm »
i took it on a long drive today...added some ATF to the fuel....seems mouch better....no real smoke to speek of....best power its had yet...the cold start lever dosent seem to do any thing and it is hooked up lol ....it was a bit hard starting this morning and ran rough for awhile.....i think some thing was sticking in it and it broke loose..... ill try the timming advance later see if it willl work now or not....it may also be stuck in advance as well ... i have no idea on this pump
Reply #3November 03, 2011, 07:32:38 pm
« Reply #3 on: November 03, 2011, 07:32:38 pm »
If it were hard to pump and pulling the advance did nothing I almost suspect you have it set too far advanced..
Do you know what you have it timed at by chance? If it is not smoking too badly and has the most power you've felt to date.. dont touch it ;) ITs running perfectly!
Reply #4November 03, 2011, 08:10:57 pm
maxfax
  • 2126
« Reply #4 on: November 03, 2011, 08:10:57 pm »
^^^ What he said..  I'm also thinking maybe your timing is a bit too advanced..  What was wrong with your old pump? Just leaking and poor performance?  Any hard starting issues with it?
Reply #5November 03, 2011, 08:23:48 pm
« Reply #5 on: November 03, 2011, 08:23:48 pm »
Run a few tanks through it and check the mileage before you go messing with it.  It may be as good as it gets.  Most of our machines run rough a bit when cold.  Do they not?  Not getting anything in the way of a response from the cold start lever makes me think to much advance as well.  But if is only a bit hard to start, leave it alone and just put your foot 1/3 to 1/2 way down on the pedal to help it come up to speed once it does fire up.  I run a second cable on the throttle lever as a means of keeping the throttle on all the time and it doubles as a high idle pull when cold.
Reply #6November 04, 2011, 01:32:46 am
guy plain
  • 121
« Reply #6 on: November 04, 2011, 01:32:46 am »
oh it starts fine....sounds like a miss now... still pulls better that ever...must have picked up 20 kms an hr on the top end....and using alot less gears on hills....when i first tryed to start it ...when the pump was first put on...it ran like a turd in a washing machine...so i looked at my old pump...factorie settings on that one i think...all wired and the metal lock was on the max fuel bolt... i tryed to set my (new) pump up so it looked about the same... sure made it run better.. i think im in the ball park... but every thing was set way different on the new pump....all the anti tamper wires where cut  ect...so i no other thing i could think of to go by...ill try pulling the advance back a bit tomorrow....do a check and make sure the cable isnt binding or something silly (silly sh!t always seems to catch me) il update here as i go...
Reply #7November 04, 2011, 01:45:49 am
guy plain
  • 121
« Reply #7 on: November 04, 2011, 01:45:49 am »
 oh as for the old pump i pull the fuel shut off and found metal shvings in it...thats the main reason i swaped it out.... forgot to mention that...oops..
Reply #8November 04, 2011, 06:51:42 am
« Reply #8 on: November 04, 2011, 06:51:42 am »
You could try retarding the timing a bit.. Do you have a gauge to measure the timing with? If you do, I would suggest checking it prior to changing it and writing it down in case you want to go back exactly.
One thing I have learned (from messing with half a dozen or so pumps on different vehicles at different degrees of wear and tear) is..
ONLY CHANGE ONE SETTING AT A TIME
If you change two or more things at once you'll never know what did the effect you got.. and going back will be friggan HELL lol.
Reply #9November 04, 2011, 09:44:38 am
guy plain
  • 121
« Reply #9 on: November 04, 2011, 09:44:38 am »
 i was thinking last night.... with a bit of metal showing in my old pump i may hve a buggered injecter as well...hence the missing sound at an idle....so  dug out a set lastnight and going to try them....i dont have a timing gauge/dial idecater so it is static timed...ill post my findings tonight...
Reply #10November 04, 2011, 10:37:08 am
« Reply #10 on: November 04, 2011, 10:37:08 am »
Maybe not that is a pretty fine screen in there.
Reply #11November 04, 2011, 11:36:40 am
mtrans
  • 308
« Reply #11 on: November 04, 2011, 11:36:40 am »
Very,very good advice,as to test min 3 days or 50 km.
I`ll improve my English
Reply #12November 06, 2011, 12:18:27 pm
guy plain
  • 121
« Reply #12 on: November 06, 2011, 12:18:27 pm »
 got a bit distraced...lol  so i picked up a engine stethascope...retarded my timing slightly....now there,s a bit of blue on start-up....runs ok but still sounds like there,s a miss for awhile at idle.... had a listen to the injecters and one dose sound different to the others... so i think ill do the swap... crap!!!  hope this will smooth the engine out a bit..
  now,.... the timming advance.... i pill it and it doesnt seem to do any thing... it used to bring my rpm,s up now there semms to be no differance ... but it dose seem to be harder to start cold with it pulled...
Reply #13November 12, 2011, 10:48:34 am
guy plain
  • 121
« Reply #13 on: November 12, 2011, 10:48:34 am »
 well i left things alone... added ATF to my fuel see if that helps...it sure seemed to...
 i did have a thought tho... i had put in a new motor mount before i did the pump...im thinking the stiffness of the new mount is making more engine noise travel through the car....making me think some things wrong when there isnt...it runs really well and its dam good on fuel (havent worked out mileage yet...but a tank last a long time)
 i also chatted with a vw mech who said... if it has good pwer and not smoking badly ... not drinking fuel like mad... just leave it... so i think thats what im going to do .....for now....i just cant leave it be for to long .... they are to much fun to play with lol
Reply #14November 12, 2011, 04:15:00 pm
Toby
  • 728
« Reply #14 on: November 12, 2011, 04:15:00 pm »
...i dont have a timing gauge/dial idecater so it is static timed....
What do you mean, you "static timed it"?
