Author Topic: Crank Bearing/Cap Bolt Removal Tool ???  (Read 3812 times)
October 05, 2011, 04:18:35 pm
Peter
  • 136
« on: October 05, 2011, 04:18:35 pm »
I know it is 17mm, but the 2 bolts on either end of the motor have no room to put a regular type socket on it..they are up tight against the block..also an open ended wrench just slips off..
Reply #1October 05, 2011, 04:21:45 pm
Re: Crank Bearing/Cap Bolt Removal Tool ???
« Reply #1 on: October 05, 2011, 04:21:45 pm »
take the seal carriers off, then you can get ANYTHING in there..
Reply #2October 05, 2011, 08:43:10 pm
« Reply #2 on: October 05, 2011, 08:43:10 pm »
i use a grinder on a OLD 17mm socket.. taking off material one the 1 side of it will let you do this no issue..
Reply #3October 06, 2011, 06:42:46 am
Peter
  • 136
« Reply #3 on: October 06, 2011, 06:42:46 am »
Thanks, so simple a solution and I should have known..it has been many years since I took one completely apart and forgot about the end covers and since this block is so covered with heavy oil/grease those little bolts can not be seen..
