Author Topic: Oil pan bolt trans side  (Read 5456 times)
August 25, 2011, 05:12:13 am
« on: August 25, 2011, 05:12:13 am »
I was checking stuff out the other day when I put my mount in and I was missing 3 bolts for the oil pan. 2 were easy. 1 is basically blocked by the trans. I know it is possible to put them in with the trans on as I have done it before. BUT I  don't know how I did it. I thought I could get it with my wobble extension, but no way. Maybe I used my bud's wobble socket, but I can't remember. Anyone have any better ideas?
Reply #1August 25, 2011, 08:29:27 am
Re: Oil pan bolt trans side
« Reply #1 on: August 25, 2011, 08:29:27 am »
That one is a pain in the @##!!! The oil pan would otherwise be so easy.
I have used a small (1/4") wobble u-joint extension. A flexible extension also worked well:
http://www.amazon.com/Flexible-Extension-Ratchet-Mechanic-Tools/dp/B00129IG7W
I think it would also help if the bolts were shorter.
Reply #2August 25, 2011, 11:03:55 am
wdkingery
  • 494
« Reply #2 on: August 25, 2011, 11:03:55 am »
i just did a pan gasket on mine, and i cross threaded both of those bolts (on accident obviously)
now they go in at the angle of attack!  ::)
Reply #3August 25, 2011, 11:52:57 am
« Reply #3 on: August 25, 2011, 11:52:57 am »
those 2 are soo easy to cross thread because they thread into the aluminum seal carrier..
i always finger those 2 bolts in, then hit them with a socket after they started in the threads..
Reply #4August 25, 2011, 12:15:12 pm
« Reply #4 on: August 25, 2011, 12:15:12 pm »
Whenever possible, when the pan comes off replace with studs and use nuts and lockwashers from then on.  Helps line up the oilpan in the first place.
Reply #5August 25, 2011, 12:19:12 pm
« Reply #5 on: August 25, 2011, 12:19:12 pm »
you only want to use like 2, or 4 studs tho.. more than that, ant it makes it harder to line it up..
it would be a bit of a bugger to line up 37 studs when re-installing the oil pan..
Reply #6August 25, 2011, 12:35:33 pm
« Reply #6 on: August 25, 2011, 12:35:33 pm »
That is correct Manly,  Just a couple where they are hard to reach and one or two on the other end.  Just to get it started and fittment correct.
Reply #7August 25, 2011, 06:43:36 pm
« Reply #7 on: August 25, 2011, 06:43:36 pm »
I cannot get my hand 1/2 way up there. I am not small at all. I don't think I could get a nut to thread on if I had a stud there. I can't get that sucker on and I need to. I think I used a wobble socket before...I guess I will have to call the snap on guy. I can see I will probably need this again.
Reply #8August 26, 2011, 10:38:56 pm
nathan_b
  • 361
« Reply #8 on: August 26, 2011, 10:38:56 pm »
1: "by hand," just means you do not use a ratchet, you can use your hand on an extension,
2: you can use a mk4+  oil pan bolt style with the 5mm allen in the center of the bolt and a "wobble" 5mm bit, it's the easiest way.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
