Author Topic: true or false?  (Read 1992 times)
August 07, 2011, 07:28:24 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
true or false?
« on: August 07, 2011, 07:28:24 am »
On 92 and earlier cars you can use a slow glow relay with fast glow plugs but you can't use a fast glow relay with slow glow plugs.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #1August 07, 2011, 07:38:53 am
Re: true or false?
« Reply #1 on: August 07, 2011, 07:38:53 am »
Assuming the correct glow plugs are used I think your statement is true.
I'm also pretty sure that the Bosch Duraterms are usable with both the slow and fast GP relays.
Reply #2August 07, 2011, 08:44:35 am
carrizog60
  • 978
Re: true or false?
« Reply #2 on: August 07, 2011, 08:44:35 am »
match the two but even unmatched i think you can start it also,assuming the engine is in good shape
Portugal
Reply #3August 07, 2011, 09:09:18 am
Re: true or false?
« Reply #3 on: August 07, 2011, 09:09:18 am »
if you use a slow timer with fast plugs, it will shorten their life..
if you use a fast timer with slow plugs, you glow it twice, and off you go..
Reply #4August 09, 2011, 07:24:35 am
erice1984
  • 263
Re: true or false?
« Reply #4 on: August 09, 2011, 07:24:35 am »
fast plugs pull more amps.  slow relay on fast plugs will likely burn the relay, and as stated before probably shorten the life of the fast plugs.
fast relay on slow plugs no harm done to either.
1980 Rabbit 1.9TD
