Author Topic: Strange galloping coconuts sound when turning right...  (Read 5075 times)
June 23, 2011, 11:29:05 am
ventureforth
  • 164
« on: June 23, 2011, 11:29:05 am »
So, whenever I turn a hard right (like all the way or almost all the way), I get this clacking sound like someone hitting two coconuts together to imitate a horse a la Monty Python.  It happens a little bit when turning hard left, but very subdued.  Turning right, it's almost comical.
Thoughts?
Reply #1June 23, 2011, 11:33:41 am
81 vw pu
Re: Strange galloping coconuts sound when turning right...
« Reply #1 on: June 23, 2011, 11:33:41 am »
Outer CV joint.
Reply #2June 23, 2011, 12:06:21 pm
rabbitman
  • 2788
Reply #3June 23, 2011, 12:17:46 pm
ventureforth
  • 164
« Reply #3 on: June 23, 2011, 12:17:46 pm »
Thanks!
Seeing as I have very limited time to do the repair, and the first free moments I get will be dedicated to troubleshooting some IP issues I'm having, how safe/advisable is it to drive around like this?
Reply #4June 23, 2011, 12:34:40 pm
81 vw pu
« Reply #4 on: June 23, 2011, 12:34:40 pm »
Thanks!
I had one start making noise last winter in the extreme cold and quit as soon as it warmed up, and its still in the caddy.
Better to replace as soon and most convenient as possible. When they break it won't move out of its own tracks.
And if it locks up or binds while at highway speeds, it could get ugly.
Reply #5June 23, 2011, 04:48:03 pm
  • 1739
« Reply #5 on: June 23, 2011, 04:48:03 pm »
Also make sure to get rid of the guy in the medieval outfit hiding in the truck. Or at least take the coconut halves out of his hands
Reply #6June 23, 2011, 06:18:06 pm
« Reply #6 on: June 23, 2011, 06:18:06 pm »
fix it before the IP or risk being turned into a Newt!  And you won't get better.
Reply #7June 23, 2011, 07:32:14 pm
rabbitman
  • 2788
« Reply #7 on: June 23, 2011, 07:32:14 pm »
I'd just grease it and slap a new boot on. Cost $10-$15 and is probably faster than R&R ing a whole nother shaft......for me anyways since I do each side every winter and rarely remove the whole shaft.
Just make sure when you pull the joint off the shaft you support the shaft so the inner joint doesn't come apart instead, pretty much doubles the work you gotta do then.
Reply #8June 23, 2011, 09:41:32 pm
« Reply #8 on: June 23, 2011, 09:41:32 pm »
I went a year daily driving a clicking axle.. left me stranded on new years eve in a blizzard enroute to a partay.
ITs up to you ;)
