Author Topic: Will a Beetle 1.9 turbo fit?  (Read 3553 times)
April 29, 2011, 10:38:09 am
trav1856
  • 230
« on: April 29, 2011, 10:38:09 am »
Can we stick a Beetle 1.9 turbo on our 1.6's?
1981 Rabbit Diesel
1981 Cabriolet
Reply #1April 29, 2011, 10:45:11 am
Re: Will a Beetle 1.9 turbo fit?
« Reply #1 on: April 29, 2011, 10:45:11 am »
dont see why not, i have an ALH turbo (VNT 15) on my 84 rabbit..
so, anything like that should fit similar..
Reply #2April 29, 2011, 10:47:41 am
trav1856
  • 230
« Reply #2 on: April 29, 2011, 10:47:41 am »
oh okay, I just wanted to make sure it'd mate up to the 1.6 block.
1981 Rabbit Diesel
1981 Cabriolet
Reply #3April 29, 2011, 10:57:53 am
« Reply #3 on: April 29, 2011, 10:57:53 am »
look at the exhaust manifold, if it LOOKS like it will fit, it most likely will.
theres only a couple different manifold patterns, and the ones that dont fit, it will be completely apparent..
what year beetle are you getting a turbo from?
Reply #4April 29, 2011, 11:13:31 am
trav1856
  • 230
« Reply #4 on: April 29, 2011, 11:13:31 am »
Thanks, Bubba...
2004
1981 Rabbit Diesel
1981 Cabriolet
Reply #5April 29, 2011, 11:14:58 am
« Reply #5 on: April 29, 2011, 11:14:58 am »
so, that SHOULD be an ALH right?
or was it some other code?
Reply #6April 29, 2011, 11:58:08 am
rallydiesel
  • 1880
« Reply #6 on: April 29, 2011, 11:58:08 am »
That might be a BEW. You will not be able to control boost with that turbo unless you make a custom actuator.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7April 29, 2011, 11:59:21 am
« Reply #7 on: April 29, 2011, 11:59:21 am »
BEW has different exhaust pattern port doesnt it?
why would he be un able to control the boost? its a VNT isnt it? not like they really need much controlling, unless you want the vanes to work so they spool faster..
Reply #8April 29, 2011, 12:18:42 pm
rallydiesel
  • 1880
« Reply #8 on: April 29, 2011, 12:18:42 pm »
All the 8v heads have the same port spacing. It's not until the common rails with the 16v heads that the manifolds change. Well, there is one euro 16v PD that is also different.
He could just keep the vanes at a fixed position like you mention, but I don't want him to think he can just hook up a tube tapped to the intake and attach it to the vacuum can and think it will work like a wastegated turbo.
Reply #9April 29, 2011, 12:48:15 pm
  • 3255
    • My collection of HOWTOs
« Reply #9 on: April 29, 2011, 12:48:15 pm »
The OEM BEW turbo has a fully electronic servo-motor vane actuator... previous versions were vacuum-controlled.
It's probably PWM, but dunno for sure. Some research will surely be required to control the vanes without the rest of the BEW bits and pieces... or it may be possible to retrofit a vacuum-controlled actuator.
Reply #10April 29, 2011, 01:14:51 pm
« Reply #10 on: April 29, 2011, 01:14:51 pm »
good point, about the electronic vane control..
Reply #11April 29, 2011, 02:33:15 pm
rallydiesel
  • 1880
« Reply #11 on: April 29, 2011, 02:33:15 pm »
No, it's vacuum controlled. I don't believe any VW turbo uses electronic solenoids to directly drive the vane arm. Unless you are referring to the electronic sensor on the vacuum can, which is just a position sensor, not an actual solenoid. Mercedes uses a solenoid to move the vanes.
