Author Topic: frustrating return line leak  (Read 4758 times)
March 10, 2011, 05:34:40 pm
motomike33y
  • 190
« on: March 10, 2011, 05:34:40 pm »
at least one of the return lines is leaking on the injector on #2 cylinder on my 1.6 na.  I have replaced it, trimmed it, tried to zip-tie it...all to no avail.  I'm about ready to try to buy some viton lines, but wonder if there are other things I haven't yet tried.  suggestions?  thanks
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1March 10, 2011, 05:52:51 pm
Quantum TD
  • 1195
Re: frustrating return line leak
« Reply #1 on: March 10, 2011, 05:52:51 pm »
I've had a return nipple crack at it's base in the injector housing. No amount of fresh rubber will solve that. I had to swap the injector body.
Reply #2March 10, 2011, 06:06:21 pm
motomike33y
  • 190
« Reply #2 on: March 10, 2011, 06:06:21 pm »
anything cause cracking? or just age?  It was working well in my other engine until the rod went, so I put the injectors in the rabbit engine. Problem surfaced immediately.  I have other bodies if that is the problem
2012 golf tdi
Reply #3March 10, 2011, 09:39:08 pm
maxfax
  • 2126
« Reply #3 on: March 10, 2011, 09:39:08 pm »
Age probably doesn't play so much into it..  Just a good bump at the wrong time will usually do..
Reply #4March 11, 2011, 03:33:27 am
rs899
  • 647
« Reply #4 on: March 11, 2011, 03:33:27 am »
I have made the mistake of cutting the old return lines off in the past and making a nick in the nipple.  When that happens, it seems likely that any new line will leak.
Reply #5March 11, 2011, 09:44:34 am
motomike33y
  • 190
« Reply #5 on: March 11, 2011, 09:44:34 am »
I'll take it out this weekend and look, I think I have a glowplug bad also, so I'll kill a couple birds with one stone.
2012 golf tdi
Reply #6March 14, 2011, 07:35:23 am
motomike33y
  • 190
« Reply #6 on: March 14, 2011, 07:35:23 am »
changed the top and fixed the leak.  now I've got a noisy injector tho and my pop-tester won't work.  sigh
2012 golf tdi
Reply #7March 14, 2011, 09:52:05 pm
  • 2926
« Reply #7 on: March 14, 2011, 09:52:05 pm »
How noisey.
 If it's banging, you don't need a pop tester to open it up and remove the piece of paint that is stuck in the nozzle,
 ha been there.
Reply #8March 15, 2011, 05:33:34 am
motomike33y
  • 190
« Reply #8 on: March 15, 2011, 05:33:34 am »
I'm going to take it out tonite and double check that I matched the right top, and the spring spacer.  It runs ratty when I start, but will smooth out when it gets warm and I'm driving 55.  It acts like its missing at idle or when first started.
2012 golf tdi
Reply #9March 15, 2011, 06:59:50 pm
motomike33y
  • 190
« Reply #9 on: March 15, 2011, 06:59:50 pm »
had a 155 bar top, which looks the same as the 130, but the source of my problem was the spacer from the 155 rather than the 130 top.  different thickness and different hole.  switched and all is well.  now on to looking at the brake master cylinder-but that's another story.
2012 golf tdi
