General Information
Troubleshooting
asf transmission flanges are loose and leaking severly
Topic: asf transmission flanges are loose and leaking severly (Read 5861 times)
November 19, 2010, 09:38:08 pm
hustonr123
November 19, 2010, 09:38:08 pm »
Both axle flanges have a lot of play and slide in and out. Is this trans junk or a easy in car fix. I have both axles removed and c clips are still in tacked.
November 19, 2010, 10:00:37 pm
Powered by Spearco
Re: asf transmission flanges are loose and leaking severly
November 19, 2010, 10:00:37 pm »
Replace the flanges and seals.
The flanges wear like that and start to leak. How many miles are on the trans.?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
November 19, 2010, 10:53:20 pm
rallydiesel
November 19, 2010, 10:53:20 pm »
They should not slide back and forth at all. I could see one spring broken but both broken is unlikely. Maybe the previous owner took the springs out for some stupid reason.
*Upon further review I learned mk1 trans may or may not have springs*
Last Edit: November 23, 2010, 02:47:43 pm by rallydiesel
1991 Jetta TD - sold
2001 Golf TDI - Son's
November 20, 2010, 08:02:29 am
hustonr123
November 20, 2010, 08:02:29 am »
There is around 220k miles on it. I replaced the clutch a month or so back and there was no leaks then. all this happened in about 2000 miles. I would like to fix this trans cause only others I can find are a 9A AGS AUG and a FF Only trans I think will fit my needs is the FF if it would only fit my car.
November 20, 2010, 06:01:21 pm
Online
2926
November 20, 2010, 06:01:21 pm »
AGS will fit a MK1 or 2,
November 20, 2010, 08:49:27 pm
Dakotakid
November 20, 2010, 08:49:27 pm »
Did these flanges float like this when you put in the clutch?
Are you sure this is not carrier bearings?
Did you still have a 5th gear that worked before you began disassembly?
This is weird stuff man! I'm guessing that trans has departed for the happy hunting grounds.
November 21, 2010, 07:00:43 am
hustonr123
November 21, 2010, 07:00:43 am »
5th gear still worked trans is out of car now the carrier is junk and ate the case up some its strange i didn't hear any noises I hate this ags trans i put in
November 21, 2010, 08:27:34 am
November 21, 2010, 08:27:34 am »
Ring gear rivot fail?
Round 2
November 21, 2010, 07:10:06 pm
Online
2926
November 21, 2010, 07:10:06 pm »
I guess there are a couple AGS gearings possible but I love the AGS in my Golf
November 21, 2010, 08:00:34 pm
November 21, 2010, 08:00:34 pm »
Love mine also. I liked it before when it had the original R&P ratio. Now with the 3.667 I like it better.
Round 2
November 22, 2010, 02:42:30 pm
hustonr123
November 22, 2010, 02:42:30 pm »
to me 5th is like 4th in asf i keep reaching over to shift up but i am already in 5th maybe my speedo is off cause at 3000 rpm in 5th I am only doin 58 mph I do have the white speedo gear installed
Reply #11
November 22, 2010, 03:05:17 pm
Reply #11 on:
November 22, 2010, 03:05:17 pm »
white gear is for 3.67 gears isnt it? and red is for 3.94 gears?
you shouldnt notice much change.. the only difference in fifth gear is that your running thru a 3.94 final drive now, instead of a 3.67..
Reply #12
November 22, 2010, 04:11:44 pm
hustonr123
Reply #12 on:
November 22, 2010, 04:11:44 pm »
how beneficial to swap in .71 5th gear feels like i have more power with this transmission just no top end
Reply #13
November 22, 2010, 05:00:33 pm
hustonr123
Reply #13 on:
November 22, 2010, 05:00:33 pm »
I just checked out this website
http://www.scirocco.org/gears/
On there it said 3k rpm with .75 5th is 70 mph for the ags
the asf trans is 75 mph at 3k rpm ether my tach is wrong or my speedo is off
Reply #14
November 22, 2010, 08:56:54 pm
Reply #14 on:
November 22, 2010, 08:56:54 pm »
red is 3.67 and 3.67 is custom in ags. White is what should be in stock ags
Round 2
General Information
Troubleshooting
