Best way to quiet your IDI!
Topic: Best way to quiet your IDI! (Read 3211 times)
October 09, 2010, 12:05:14 am
Smokey Eddy
October 09, 2010, 12:05:14 am »
I replaced all my lifters and HOLY is it ever quiet!
Just thought i'd share that with everyone.
Such a massive difference... what i thought was injector noise was lifter noise.
what i thought was lifter noise was lifter noise.
what i thought was diesel combustion noise was mostly lifter noise!!!
Ed
THROWN ROD
October 09, 2010, 12:08:03 am
Re: Best way to quiet your IDI!
October 09, 2010, 12:08:03 am »
lifters get super loud. my 1.8 gasser sounded almost as rattley as my diesel before i changed the cam and lifters.. then it got almost silent.
October 09, 2010, 03:08:36 am
hooper
Newbie
October 09, 2010, 03:08:36 am »
been thinking of doing this as mine seems a little over noisy(could be fine as im used to more modern diesels) and what i assumed was diesel knock seems unaffected by timing adjustments. i put it down to an injector issue as the engine had been stood for 7 years b4 i got it but maybe theres some tappet noise lurking there somewhere. ive had the rocker cover off to check the camshaft and theres no visible wear to anything.
October 09, 2010, 08:41:46 am
GEE-BEE
October 09, 2010, 08:41:46 am »
same here after a new complete head assy....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
