Waterpump pulley
Topic: Waterpump pulley (Read 2344 times)
October 04, 2010, 07:40:44 am
gnavs
Waterpump pulley
October 04, 2010, 07:40:44 am »
So I'm nearing the end of my AAZ rebuild and need some additional info regarding the waterpump pulley. I've deleted the AC and power steering and am left with a water pump that wants to be run by the V belt and not the serp. What I need is a serp pulley to install on the water pump so I can just run one belt for all of my accessories. I did some research yesterday and it sounds like the VR6 pulley will work but I'd like to hear what some of you have done.
I'll likely be fabbing a tensioner like Lucas' here to keep things toight.
TIA
October 04, 2010, 08:51:37 am
rodpaslow
Re: Waterpump pulley
October 04, 2010, 08:51:37 am »
Yup VR6 pully is the one to use. Mine needed a spacer to run in the center of the belt, I just used the center part of the v-belt pulley cut out as the spacer. But, the vr6 water pump pulley is the one you want.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
October 04, 2010, 05:48:24 pm
gnavs
October 04, 2010, 05:48:24 pm »
Sweet, thanks. Is it MK3 specific or can I use a MK4 pulley?
Waterpump pulley
