Author Topic: Bleeding brakes w/4 lines loose ? ?  (Read 4798 times)
September 01, 2010, 05:36:42 pm
doonboggle
  • 179
« on: September 01, 2010, 05:36:42 pm »
I'm now almost to the point of bleeding my brake system with the new wheel cylinder and caliper cylinders in place.  But ... having read a post advising to not infect new cylinders with old, and possible 'bad' fluid, by flushing all 4 lines.
But does anyone have a process for this ... considering that if all 4 lines are open, and pumping takes place with the pedal, a lot of new fluid will be wasted ... more than IMO ... what is wasted when just one line is flushed.
I realize that one can attach hoses and drain into a bottle ... but I'm asking how to temporarily 'plug' up the other 3 lines while the 4th line is being flushed.
TIA
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
Reply #1September 01, 2010, 06:59:34 pm
Baron VonZeppelin
Re: Bleeding brakes w/4 lines loose ? ?
« Reply #1 on: September 01, 2010, 06:59:34 pm »
You won't get anywhere using the pedal with all 4 lines loose.
Each time pedal comes back up - will suck air back in the lines.
Will just keep going back and forth in the line - with little flushing.
I don't know how to cap the lines in a way that would hold the other 3 sealed while you work 1 with a gloved finger. Maybe a hardware store with a Good brass section might have something.
But it needs to be metric thread.
Probably need a Mighty Vac tool or 1 man brake bleeder or similar, to suck fluid out each line one at a time. To get initial old stuff out. Then after that for a bit - hook em back up and do it all again with the pedal.
Thats how i did mine. (Mighty Vac tool)
Reply #2September 01, 2010, 07:29:59 pm
« Reply #2 on: September 01, 2010, 07:29:59 pm »
You can gravity bleed just by leaving the bleeders open for an extended period of time. Unless your fluid is really, really bad this whole idea is probably overkill.
Reply #3September 01, 2010, 08:15:49 pm
« Reply #3 on: September 01, 2010, 08:15:49 pm »
I'd have to agree with fire yer dough.  Most likely you have dripped a good portion of the old fluid out of the lines just doing the work.  As careful as I try to be and not get fluid all over the place I get fluid all over the place.  So the lines are fairly open already.  I would connect them up and start pumping and watching the reservoir.  Do not let it suck air into the lines, or get low.  I think you pulled most of that old crap out of there anyway so your lines really only have a little section of old fluid in them.
When you bleed each brake I bet you will be able to tell when you go from bad/old fluid to new/good stuff.  At least if you are watch a clear line or the side of the jar.  That dark stuff is old the clear is the good.
Overkill to drain all four, yep, just bleed em and call it good.
My nickel worth, inflation you know.
Reply #4September 01, 2010, 08:24:12 pm
  • 3255
    • My collection of HOWTOs
« Reply #4 on: September 01, 2010, 08:24:12 pm »
If you've got a source of compressed air you can apply gentle air pressure to the brake fluid reservoir (seal the top around the air hose with your hand or modify a cap from a junker) and speed the draining process.  Low pressure only... no more than 15 psi or evidently the MC seals will go.
I've built a brake fluid reservoir cap with an air fitting attached specifically for this purpose... also works to pressure-bleed the brakes with new fluid.... which of course we all do religiously every two years, like the Bentley recommends.   ;)
« Last Edit: September 01, 2010, 08:26:14 pm by Vincent Waldon »
Reply #5September 01, 2010, 09:02:16 pm
« Reply #5 on: September 01, 2010, 09:02:16 pm »
Ya sure Vince!  That is why we are the PROUD owners of 30 year old cars.
Every two years  shheesseee
Reply #6September 01, 2010, 10:31:41 pm
Baron VonZeppelin
« Reply #6 on: September 01, 2010, 10:31:41 pm »
I forgot about the pressurized cap trick.
There was a thread a while back talking about it - with a link to another thread somewhere. Guys were using pump up garden sprayers for the source of pressure - as one method.
Its too easy to say this now - and hindsight 20/20 - but bleeding the piss out of them before tearing it down would have been the way to go.
yeh i know .... why ya wanna tell me that now .... lol
Reply #7September 01, 2010, 11:10:48 pm
doonboggle
  • 179
« Reply #7 on: September 01, 2010, 11:10:48 pm »
It occurred to me to go   to the local hardware outlet and get 3 of the shortest metric bolts, and some plumbing sealant 'tape' (forget it's name just now) I use on my sprinkler system.
Screw the bolts, with about 2-3 circles of the sealer tape around the threads, in 3 inlet connections of the M/C finger tite, and the 4th with it's steel line to the first cylinder ... and bleed.
Then leaving that connection there, do the same with the remaining 3 ... one by one ... by removal of the bolt.  Should help to prevent a big mess.
doonboggle
2006 Jetta TDI
Reply #8September 02, 2010, 04:22:39 am
rs899
  • 647
« Reply #8 on: September 02, 2010, 04:22:39 am »
Yeah, I use one of those pressure bleeders that I made out of an old garden sprayer that had a bad nozzle.  I just found a way to adapt it to a spare cap.  Put some fluid in it , give it about 10 strokes and bleed away.  Greatest thing since sliced bread (actually, I hate sliced bread).  Takes about 10 minutes to bleed a car that way and no whining from SWMBO.
Reply #9September 02, 2010, 10:52:36 am
Baron VonZeppelin
« Reply #9 on: September 02, 2010, 10:52:36 am »
Sounds like a good try Doon.
I'd put an old large towel or something under the MC - something that will act like a diaper. There probably will be leakages. Just in case.
Reply #10September 02, 2010, 01:00:14 pm
doonboggle
  • 179
« Reply #10 on: September 02, 2010, 01:00:14 pm »
So far ....
1.  MC plugged outlets ... no leaks.
Yesterday, before beginning this, 'mouth' blew into the MC with some fluid in it ... and got a steady stream out of all 4 outlets ... one by one.
Also no leaks around the reservior '30 year old' plugs ... presumably ... either.
2.  Have 3 lines plugged with my bolts, and #4 connected ... then pumped like heck and no real amount of old fluid came out ... but more importantly did get 'swoshing' sound, and drops ... indicating that at least that line is empty.
3.  All of this is being done with no imput from the servo ... but apparently getting enough pressure thru the line from the pumping to force old fluid out, and air through.
Now on to others.
Have noticed though that with the rebuilt K-H calipers on the front, one of the wheels is dragging against the pads.  Wonder if that will improve once the servo is incorporated into the process with engine running???
By the way, if anyone needs a rebuilt K-H caliper, have one.  While Rockauto had a swinging deal on them, close-out, they were not too sharp with shipping the initial order.  One had everything in it ... but the other one was without the mounting frame.
Notified them ... and after a day of contemplating, they informed they'd send another one ... and to not return the first 'guts' of the item.
So yesterday the replacement, with frame arrived ... but lo and behold, this time the bleeder plug was broken off.  [Looks like these 'buggered' units were returns from former customers, that the company merely put back on the shelf ... and now in their 'close out' sale, are shipping them out as good units.]  Thankfully, having kept the first 'buggered' one, I merely took the frame off this latest one and used the aforementioned 'guts' item ... and now have a complete caliper as advertised.
So have a 'guts' part of the K-W ... and extra pair of new pads ... if anyone's interested.  Presume that if you have the ability to back out the broken off bleeder, you'll have a good unit.  Did see ... can't recall where though ... seeing new bleeders posted somewhere.
doonboggle
2006 Jetta TDI
Reply #11September 02, 2010, 09:30:22 pm
Baron VonZeppelin
« Reply #11 on: September 02, 2010, 09:30:22 pm »
What a bummer on the KH caliper.
Least they made it right.
RockAuto is who got suckered on that.
They bought those out, and musta been some "bad apples" in the batch. You get the good and the bad when you buy the lot.
Hopefully they will start inspecting the rest of them before shipping. That isn't good for business.
