Author Topic: Brake parts advice follow-up  (Read 6650 times)
August 25, 2010, 11:55:20 am
doonboggle
  • 179
« on: August 25, 2010, 11:55:20 am »
OK, at ... http://www.vwdiesel.net/forum/index.php?topic=26684.0 ... I laid out my hesitance to tackle my brake problem on my 81 diesel pickup.  As a result of guidance and responses, I now have much of the parts en-route in the next day or 2.  Today I decided to start taking stuff off to be ready.
I began with the master cylinder, and with it now off, see some issues that I need to get comments on please.
First, I cannot identify which brand the master cylinder is; Bendix, etc., ??  Is that an issue, or will any new (if I decide to replace it) one be OK?
Second, with it off I now see rust where it connects to the servo ... and also rust inside the servo on the pushrod.  I had hoped to not to have to replace these items ... almost 200.00 already in the 'hole' with this month's retirement income.
Images are down below this.
Based on the rust, is it imperative that I replace the m/c and servo?  The servo will be a problem due to the difficulty of getting to the nuts holding it.
Thanks
M/C left side.
M/C bottom
M/C right side
M/C to servo 1 & 2
Servo to M/C
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
Reply #1August 25, 2010, 07:58:21 pm
Baron VonZeppelin
Re: Brake parts advice follow-up
« Reply #1 on: August 25, 2010, 07:58:21 pm »
No real problems there. Just not pretty looking is all.
Could do some minor cleaning and greasing to keep it in check and better preserved.
Usually when the MC starts going bad - the rear end is where they start leaking from. Being dry is a good sign.
Don't use any sealant where the MC mounts to Pwr Booster as a preventive measure - if it starts leaking fluid eventually - you'll want it to be able to escape and get your attention.
Kelsey-Hayes MC @ Rock = $23
Having the right ports in the same locations is the main key.
Dammd nice luck the brake line fittings came out so nice.
Mine are waiting to torture and induce bloodshed.
Reply #2August 25, 2010, 08:12:14 pm
  • 3255
    • My collection of HOWTOs
« Reply #2 on: August 25, 2010, 08:12:14 pm »
Just one cautionary note... and I'll admit to not having had a Pickup for a while, but it's my understanding that the truck brake boosters are NLA and are getting darned hard to find.
If so, it may just mean that you need to treat the one you have like it's made of glass unobtainium as you disassemble things further and/or live with the rust you've got.
Or perhaps there's a good supplier out there someone knows about?
Reply #3August 25, 2010, 08:35:40 pm
« Reply #3 on: August 25, 2010, 08:35:40 pm »
Doondoggle,  I would say that you have nothing to fear using these parts.  And if a Midwestern had these "rusty" parts they would be jumping for joy.  They would class them as "new".
Rusty?  What rust?
Reply #4August 25, 2010, 09:57:02 pm
doonboggle
  • 179
« Reply #4 on: August 25, 2010, 09:57:02 pm »
So Or, Vince and Baron ... this is a surprise to me.  Had envisioned that I would need to replace the items ... especially where the rubber plugs are inside and cruddy looking ... focusing on the booster for one.
And of course the 'C' clip ... or whatever it is called in the M/C ... being as bad looking also.
So next move ... try to clean up as best as possible and re-assemble???????
And move on to other things ......CORRECT ? ?
The M/C is a Bendix, based on the rubber plugs where the reservoir goes ... and they have dried evidence and aging signs ... but cannot seem to find them ... and 'yes' Vince, the booster is a hummer cost from what I've located so far.
But .... why the rust?
Should not there be a seal where the 2 parts are joined to keep water out.
OH! !  And what would one do to clean out the reservoir good?  I used a bit of gas and shook it 2-3 times ... but the caked sediment (?) is still there; and there's no way to take it apart to get in all the corners, etc..
« Last Edit: August 25, 2010, 10:15:12 pm by doonboggle »
doonboggle
2006 Jetta TDI
Reply #5August 25, 2010, 09:59:21 pm
maxfax
  • 2126
« Reply #5 on: August 25, 2010, 09:59:21 pm »
The difference between the master cylinders IIRC is the number of outlets..  THe 4 outlet seems to be the most common..  I *think* there other only has 3.. Someone please correct me if I'm wrong..
Doon, the seal between the booster and master is that little rubber round disc that the rod comes though..  Otherwise air and moisture can get in there where yours is  "rusty" (that is really pretty clean in comparison to what I see here in the North East)..   Pretty typical on any vehicle.. The idea of that area not being sealed tightly is so that if the master cylinder leaks you can see the fluid running out between the booster and master cyl..  And the fluid draining out between there is much better than it making its way into the booster..
Clean and reassemble and you should be good..  I too have never found the little grommets for the reservoir, except with a new master cylinder..  Fortunately all the sealing takes place down inside, and there is next to no pressure on them..  I've had some pretty crappy looking ones seal up just fine...
The power brake boosters are still available, they just take some time to get..  Carquest part number 53-5600, they list for like $197..  I suspect they get them through World Pac..   Pretty sure they can be gotten cheaper  ;) ..
« Last Edit: August 25, 2010, 10:07:39 pm by maxfax »
Reply #6August 25, 2010, 10:18:42 pm
doonboggle
  • 179
« Reply #6 on: August 25, 2010, 10:18:42 pm »
If you're referring to the one I have, it is the 4 line connection type ... with the adjustment 'thingie' underneath with the fluid passing through.
TIA
doonboggle
2006 Jetta TDI
Reply #7August 25, 2010, 10:29:38 pm
  • 2926
« Reply #7 on: August 25, 2010, 10:29:38 pm »
From my experience with brake parts/seals:,..
 they don't like petroleum products.
 Did you put gas in the resevoir with it still attached to the master cylinder?
That might have ruined it.
Reply #8August 25, 2010, 10:40:30 pm
Baron VonZeppelin
« Reply #8 on: August 25, 2010, 10:40:30 pm »
"Most" use the 4 port set-up.
But there are different locations for the ports - as you can see where there are blank spots on the sides of yours.
Some have all 4 on the sides.
Some have the ports where yours has blanks, and blanks where yours has ports, and still use the 2 bottom ports.
And some are just like yours.
And some have smaller bores, and some have larger bores.
I've cleaned a few of the reservoirs out that were nasty, and had good results. Use Brake Fluid as your solvent.
Use long oversize pipe cleaners doubled up (don't remember where i got them) as "swabs". Takes a little bit of time - but have gotten them back into really nice condition even in the rearward corners.
Considering they are right around $100 new, and nobody has them aftermarket - its worth an hour or so to get it cleaned up nice on the inside.
Either put the MC in a Vise or back on the Truck before attempting to remove the reservoir. Unless you're not going to remove the reservoir at all.
Brush off what rust you can, apply some grease over it all - put it back together - fuhhhget aboutet.
Reply #9August 25, 2010, 10:44:06 pm
maxfax
  • 2126
« Reply #9 on: August 25, 2010, 10:44:06 pm »
I was looking at pictures at venders..  Seems as though there is a 4 port and a 6 port..   Yet it looked like the 6 port had plugs in 2 ports..  ???
Reply #10August 25, 2010, 10:45:53 pm
doonboggle
  • 179
« Reply #10 on: August 25, 2010, 10:45:53 pm »
NO !
doonboggle
2006 Jetta TDI
Reply #11August 25, 2010, 10:50:41 pm
doonboggle
  • 179
« Reply #11 on: August 25, 2010, 10:50:41 pm »
I've cleaned a few of the reservoirs out that were nasty, and had good results. Use Brake Fluid as your solvent.  Use long oversize pipe cleaners doubled up (don't remember where i got them) as "swabs". Takes a little bit of time - but have gotten them back into really nice condition even in the rearward corners.
O-BOY --- finding long pipe cleaners in this hicks-ville village is another story....
That's how I got it apart today.  You must've been peeking into my garage.
Best news of today...
doonboggle
2006 Jetta TDI
Reply #12August 25, 2010, 10:52:22 pm
Baron VonZeppelin
« Reply #12 on: August 25, 2010, 10:52:22 pm »
6 port MC was for the Rabbit Dually Truck, that never made production.
It was slated to have dual calipered rear disc brakes on each side.
okay .... i made that up   :P
Reply #13August 26, 2010, 09:36:53 am
Baron VonZeppelin
« Reply #13 on: August 26, 2010, 09:36:53 am »
Some regular length pipe cleaners will probably work too.
Could just double a small length at the end as the "swab".
Or wad up a small section of cut cloth and twist it on tightly at the end of the pipe cleaner.
Or tie 2 pipe cleaners together.
Some creativity and ingenuity will clean these things up almost as new.
Reply #14August 26, 2010, 09:41:41 am
doonboggle
  • 179
« Reply #14 on: August 26, 2010, 09:41:41 am »
I've cleaned a few of the reservoirs out that were nasty, and had good results. Use Brake Fluid as your solvent.  Use long oversize pipe cleaners doubled up (don't remember where i got them) as "swabs". Takes a little bit of time - but have gotten them back into really nice condition even in the rearward corners.  Considering they are right around $100 new, and nobody has them aftermarket - its worth an hour or so to get it cleaned up nice on the inside.
Yes, find them in several web vendors, even at busdepot.com.  Most in the 125.00 range, plug shipping.  Their model number, 867611301B, has a different cap than the pickup; but if one keeps the old cap, looks like it'll be OK.
OH !!  And discovered why the rust between M/C and servo ... no O-ring there.
doonboggle
2006 Jetta TDI
