AAZ Serpentine Belt Question
Topic: AAZ Serpentine Belt Question (Read 10655 times)
August 02, 2010, 06:34:53 pm
VW_Commuter
August 02, 2010, 06:34:53 pm »
I have an AAZ Serpentine belt conversion done on my '91 Jetta by the PO with an A/C and powersteering delete done at the same time. I would like to have the A/C restored but don't want the powersteering and I know we had a discussion about that a few weeks ago but for the life of me can't find it in a search. I know that one of our European members listed the part number for an A/C compressor that rotated backwards and the serpentine belt that allowed the use of a single serpentine belt. I've found a belt routing diagram in ETKA -
And was wondering if anyone can remember the post and possibly post the link to it.
Thanks
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
August 02, 2010, 08:29:54 pm
Re: AAZ Serpentine Belt Question
August 02, 2010, 08:29:54 pm »
http://www.vwdiesel.net/forum/index.php?topic=9599.0
Maybe that one?
Round 2
August 02, 2010, 09:35:03 pm
VW_Commuter
August 02, 2010, 09:35:03 pm »
That's the one but the waterpump is what turned CCW
I'd like to find out the part number is for the A/C compressor in the diagram and also the serpentine belts part number and dimensions. This would be the ideal setup for those who want A/C but don't want power steering. I'll have to keep researching to see if I can identify their part numbers.
Greg
August 03, 2010, 05:17:19 am
August 03, 2010, 05:17:19 am »
The a/c unit should be a sanden 508, there are some on ebay for 90's mkiii aaz golf's 193.00 each. I am saving up and doing the same deal you are once I get it all together. Once you have the correct brakets the water pump I think still needs driven by the v belt with an adjustable pulley *going from what others have told me on some of this* . The belt should be a 6pk 1145. Here is a link on the vortex that has info for gassers mainly, but you can take most for diesels and apply.
http://forums.vwvortex.com/showthread.php?4773933-MK1-ABA-swap-A1-ABA-swap-Rabbit-ABA-swap-Rabbit-2.0-swap-2.0-into-A1-2.0-into-MK1-info-thread&highlight=serpentine+crank+pulley
on autohaus there is a hancock compressor part # 1H0820803D for 341.95
This is the info on the ebay one
A/C Compressor & Clutch Part Brand: TechChoice Parts
Year Model: 1995 Interchange Part Number: 1H0 820 803 D, 1100, 1105, 4252
Vehicle Make: Volkswagen Other Part Number: 57591
Vehicle Model: Golf Part Type: Air Conditioning & Heat
Manufacturer Part Number: 30607N
Then there is a sanden 508 for a jeep that is identical to the VW one except it has lines coming from the top of the unit instead of the back and it is around 100.00
Round 2
August 03, 2010, 07:54:09 am
VW_Commuter
August 03, 2010, 07:54:09 am »
If you look at the cropped pic that I posted and follow the belt as if the A/C compressor isn't there then you can see the setup that I currently have. I've got an AAZ bracket, AAZ alternator, what appears to be a VR6 water pump pulley, and no A/C compressor or power steering pump. Basically it's the pic I posted w/out 'F' and you can see they show the belt path both ways. The A/C compressor for an AAA VR6 motor spins CCW and if the center-to-center bolt holes match the ones on the bracket then all I will need is the compressor and then to find a double ribbed serpentine belt in the proper length and you can have A/C with a single serpentine belt. If I can find this info then it would be an easy conversion and one sweet setup.
Greg
August 03, 2010, 09:35:31 am
VW_Commuter
August 03, 2010, 09:35:31 am »
Andrew, I certainly will post all the info if I can make it work.
Greg
August 03, 2010, 02:20:45 pm
August 03, 2010, 02:20:45 pm »
That would help me a ton too. I have been waiting to do a/c for a while and now am glad. Let me know if you find something and need help searching. I now understand what you were looking for. Basically, you need to find a VR6 compressor and see if it works. I will try to find one and let you know as well
Round 2
August 03, 2010, 03:33:01 pm
VW_Commuter
August 03, 2010, 03:33:01 pm »
Exactly. If the VR6 A/C compressor will fit the AAZ mount then all we have to do is find the right length double ribbed serpentine belt and we should be in business. Of course you also need the clutched pulley on your alternator and should do the TDI crankshaft sprocket mod to ensure a long and happy life for your engine
If this works then we can have A/C, no power steering, and never deal with a v-belt ever again.
Greg
August 03, 2010, 03:55:43 pm
August 03, 2010, 03:55:43 pm »
would it have to be a double rib?
BTW...I have prepared for this. Crank sproket mod, clutched alt pulley installed, and no a/c lines or cash LOL.
Even if it doesn't bolt right on it should be easier to make a new adapter bracket than to try and source a compressor that would work. I have been looking for cheap alternatives for the aaz one and like I said earlier I found a jeep one. Takes forever and I don't know 100% that it will work.
Round 2
August 03, 2010, 03:59:36 pm
August 03, 2010, 03:59:36 pm »
I am already looking. This one is only 99.99 buy it now
from the looks of it, it has mounting tabs like the others, but not as many.
*old* but shows that the tabs should work if the spacing is similar as it does have both.
this is what it says about alternate part#
Competitive Part Reference
ACDelco 15-20994, 15-21500
Denso 471-7001
Four Seasons 57592
Frigette 204-827, 204-1553
NAPA 254074
Omega 20-15402
Ready-Aire 2257, 2257N
Sanden 1102
Visteon 000485, 010463
Last Edit: August 03, 2010, 04:15:22 pm by theman53
Round 2
August 09, 2010, 03:31:52 pm
August 09, 2010, 03:31:52 pm »
I talked to my a/c guy today and he said that the pump really doesn't care about which way it is spinning. All we really need to watch is that the lines leaving it go UP or are 3/4 the way up the unit. That way all of the oil won't leave the compressor. He also said that sandens were junk compared to other units, but they can be clocked so we could mount them in other locations. I will experiment eventually if no on else does
Round 2
Reply #11
August 10, 2010, 05:30:31 am
Reply #11 on:
August 10, 2010, 05:30:31 am »
I am looking into a ribbed water belt pulley and a double groove belt. I was just pleased to find out that pretty much as long as your lines are ran upwards you can make a compressor work in either direction.
Round 2
Reply #12
August 10, 2010, 04:34:04 pm
Reply #12 on:
August 10, 2010, 04:34:04 pm »
http://www.tld-corvette.com/prodinfo.asp?number=578916
They make double ribbed belts...now to see how long I will need and how long this one is. This is a Corvette belt, but I have found that some Volvo's had them and possibly a Lexus too.
Round 2
Reply #13
August 10, 2010, 09:54:16 pm
VW_Commuter
Reply #13 on:
August 10, 2010, 09:54:16 pm »
i just picked up all of the underhood A/C parts less the compressor for $75 and a VR6 A/C compressor for $40. As soon as I have my IP back together and the engine running I'm going to start putting the A/C back in it.
Greg
Reply #14
August 11, 2010, 06:01:49 am
Reply #14 on:
August 11, 2010, 06:01:49 am »
I am running mine with no a/c and one vbelt until I get the rest of the lines, compressor, and condenser. I have most of it but the condition is shakey on most of it. Looking forward to you getting yours done and posting pics. I plan for 2011 for mine.
Round 2
