AAZ exhaust ? PICTURES ADDED
Topic: AAZ exhaust ? PICTURES ADDED (Read 2410 times)
April 27, 2010, 09:51:35 pm
gribur
April 27, 2010, 09:51:35 pm »
hi there. i have an 94 golf with the AAZ in it. The piece that comes from the turbo down is made of cast iron, it is then attached to another piece of downpipe with some sort of C clamps. I looked on the net and found a downpipe for the AAZ and it does not have the c clamps and it has flex pipe. Whats with my downpipe? It also have the K-14 turbo. Just confused, please enlighten me.
cheers
Larry
Last Edit: April 28, 2010, 07:38:50 pm by gribur
April 28, 2010, 06:40:59 am
Re: AAZ exhaust ?
April 28, 2010, 06:40:59 am »
Strange, sounds like you have a downpipe off a much earlier engine! Can you attach a photo?
April 28, 2010, 07:00:39 am
Mozza
Re: AAZ exhaust ?
April 28, 2010, 07:00:39 am »
yeah they used the c clamp things on most the mk2 and in the gtd engines but i had the downpipe replaced with the standard aaz one when the engine went in, Piks would be great
April 28, 2010, 07:38:24 pm
gribur
Re: AAZ exhaust ? PICTURES
April 28, 2010, 07:38:24 pm »
I was able to snap a few pics today, maybe this will shed some light on my exhaust. Open to suggestions.
April 28, 2010, 07:49:01 pm
GEE-BEE
Re: AAZ exhaust ? PICTURES ADDED
April 28, 2010, 07:49:01 pm »
It's a toliet bowl with a cat from a 1.6 TD ?
You need a new downpipe assy in either 2.25 or 2.50 in S/S and replace those rubber hoses also there in bad shape ( pic )
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
April 28, 2010, 09:19:06 pm
gribur
April 28, 2010, 09:19:06 pm »
would you suggest replacing all rubber lines? also where is a good place to get the steel injection lines? i think thats what they are called, the really rusty ones. I am in ontario, canada. Can you order the rubber lines or do you just buy hose from the auto store in the same diameter and put it in?
April 29, 2010, 07:39:36 am
GEE-BEE
April 29, 2010, 07:39:36 am »
If you fuel in and out is soft line ( 7 MM )
Filter to pump ( hose assy banjo to banjo ) 12.00
some are 2.5mm manifold to pump ( vacuum )
turbo wastegate 3.5 mm
Any vw shop will have the vw cloth type
There is a nice kit from greaseworks.com for the injectors with cap
Dont forget new nozzle brackets ( injectors ) 3 total
2 each that hold 2 lines, one each that holds four lines
I dont have the AAZ hardline part #'s , stock up there since it's a aaz
get the downpipe that is in the For sale section from Farkman !
Done
Last Edit: April 29, 2010, 07:42:39 am by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
April 29, 2010, 09:42:05 am
farkman
April 29, 2010, 09:42:05 am »
Quote from: GEE-BEE on April 29, 2010, 07:39:36 am
Done
Better yet, get the whole exhaust system
