cracks in the turbo housing
Topic: cracks in the turbo housing (Read 3700 times)
March 10, 2010, 08:23:18 pm
sdwarf36
March 10, 2010, 08:23:18 pm »
I tore down the turbo I was gonna use-after cleaning I found this crack.Is this bad enough to wory about?
Also-is this a T3? there is a marking "M4" cast into the housing-also ".36" on the inside.
91 Jetta on WVO na / td swap in progress.
"VW happiness is having 4 working door handles."
March 11, 2010, 12:47:08 am
rabbitman
Re: cracks in the turbo housing
March 11, 2010, 12:47:08 am »
Don't know about the crack but I know that flange doesn't look anything like the normal T3's.
March 11, 2010, 07:04:40 am
March 11, 2010, 07:04:40 am »
its not VW. its a T3 off a chrystler or something probably.
March 11, 2010, 11:45:05 am
macka
March 11, 2010, 11:45:05 am »
looks like a mitsu T3
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
March 11, 2010, 07:45:04 pm
sdwarf36
March 11, 2010, 07:45:04 pm »
It came attached to an aftermarket exhaust header-bolts up to the 4 outer bolts. It gives the room to run a gasser intake. Not so worried what it originally came from -just want to make sure i order the right rebuild kit. So no-one is worried about the crack?
March 12, 2010, 06:55:25 am
March 12, 2010, 06:55:25 am »
its going to get bigger, unless you stop it right now.
