Author Topic: PD150 Intake manifold/info  (Read 8684 times)
February 07, 2010, 07:08:31 am
ein bora
  • 377
« on: February 07, 2010, 07:08:31 am »
Want to start collecting stuff for a possible performance rebuild on my 1.9 IDI. Read a number of posts on the PD150 Intake manifold and have a number of question hopefully someone can help me out with.
- Haven't really done an in-depth search but are PD150 Intake manifold all the same or is there a specific one I need to use that will fit the 1.9 IDI.
- As I have no idea as to what they are worth - what's a fair price that I can I expect to pay for one?
- Is there any mod's that will need to be done in order to get it to work.
Or any other info that I may need to know. Thanks in advance.
If you can't take advice - then you can't be helped!
Reply #1February 07, 2010, 07:50:54 am
GEE-BEE
  • 1604
Re: PD150 Intake manifold/info
« Reply #1 on: February 07, 2010, 07:50:54 am »
Talk with member RYANP on these
There is PD130 & PD150 model's
You will need the race pipe from vendor
Streetoys2000.com
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 07, 2010, 08:01:28 am
deathhare
  • 74
« Reply #2 on: February 07, 2010, 08:01:28 am »
What are the advantages of just adding this intake and doing nothing else?
Reply #3February 07, 2010, 08:27:49 am
« Reply #3 on: February 07, 2010, 08:27:49 am »
not much..
not as much biasing to the middle cylinders. thats about it. but a stock motor, with stock boost and stock fueling, wont gain much i wouldnt think. other mods are what makes the PD intake shine.
Reply #4February 07, 2010, 11:49:24 am
ryanp
  • 269
« Reply #4 on: February 07, 2010, 11:49:24 am »
tuned tdi's have been known to burn out cylinders due to un-even flow with the ALH intakes, these PD150 (facing cambelt) or 130 (facing gearbox) are good past 250hp, people with more have them though.
There are a few varients but most fit only the later 2008onwards look similar but need more work to fit.
I get discount with Street toy's for the race pipes too!
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #5February 07, 2010, 03:26:19 pm
blackdogvan
  • 574
« Reply #5 on: February 07, 2010, 03:26:19 pm »
What about the 2 piece PD manifold, the one with the butterfly valve assembly (anti shudder valve?) built in?
1991 Vanagon 1.9 mTDI
Reply #6February 08, 2010, 01:49:16 am
ryanp
  • 269
« Reply #6 on: February 08, 2010, 01:49:16 am »
the butterflies are waiting to be ingested into your engine! lol
I've sent quite a few to people removing those crappy things, they sometimes go as far as swapping the head to get rid of the split ports as it's only for emmissions reasons!
Reply #7February 08, 2010, 08:43:31 am
blackdogvan
  • 574
« Reply #7 on: February 08, 2010, 08:43:31 am »
Well they are easy to find over here but maybe not worth the bother...
