Author Topic: My first motor swap.  (Read 4430 times)
Reply #15January 30, 2010, 03:50:46 pm
dash cunning
  • 47
Re: My first motor swap.
« Reply #15 on: January 30, 2010, 03:50:46 pm »
you need the 5 speed gear selector shaft, 5 speed ball, and 5 speed linkage rods and that's it. ;)
79' rabbit 1.5 n/a, 89 golf gasser, 91 jetta gasser, 72 westy.
Reply #16January 31, 2010, 08:31:36 am
GEE-BEE
  • 1604
« Reply #16 on: January 31, 2010, 08:31:36 am »
Get a 5 speed rebuild kit, easy and all the stuff you will need if worn
selector plate from v.w. 55.00
Dont forget to spoil yourself with a new leather knob !
What engine are you installing ?
G.B.
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #17February 01, 2010, 11:06:40 pm
superbro
  • 45
« Reply #17 on: February 01, 2010, 11:06:40 pm »
1.6n/a
2005 TDI Jetta Wagon 5 speed.
 Sold :'( 1983 Caddy 1.6 N/A 5 speed. Daily driver.
Reply #18February 02, 2010, 05:46:28 am
lovinthedeez
  • 489
« Reply #18 on: February 02, 2010, 05:46:28 am »
i use one of these cheapo harbor freight dollies to roll it out.  this rabbit needed only to go a little higher up to roll the whole thing out.  And I did this by myself for the most part in the span of a few hours.  remove wheels and axles.  lower until motor sits on dolly.  unhook electrical, and exhaust, motor mounts.  lift (you'll want at least one biggy jack for this part to get it high enough.)  motor rolled right out with both manifolds still attached.
« Last Edit: February 02, 2010, 09:59:51 am by lovinthedeez »
Reply #19February 02, 2010, 02:19:26 pm
superbro
  • 45
« Reply #19 on: February 02, 2010, 02:19:26 pm »
Sweet!
