Author Topic: Are all VE pumps like this?  (Read 3062 times)
January 13, 2010, 04:27:01 pm
lovinthedeez
  • 489
« on: January 13, 2010, 04:27:01 pm »
So my little lady was so nice to get me a new metric dial indicator and adaptor so I can finally time my pump.  I've never had to do the actual pump timing, even though I've done head gaskets and timing belts a  bunch of times.  guess I was just lucky. ;D.  So background, its a 1.6 n/a from a 81 rabbit.  so according to the bentley, I should be at .088 + or - .02.  I did that, and got the same number over and over and over, so I knew I had the routine right.  So after trying to start it over and over and over, I tried a few different settings.  timed it prolly ten times, and never got a good startup when cold (it ran fine before ::))  so I cleaned up everything and found some stampings by where the mark is to line up the pump by the pulley.  it had a .095 stamped above a .112.  So I timed it up to .103, and voila.  so since I don't have another pump to look at.  do they all have a stamping like this?  maybe rebuilt? maybe mk2?   I have bentleys for the mk1 and 2; and neither have tolerances of .095-.112.
whew.....you made it.....thanks for reading.....
« Last Edit: January 14, 2010, 03:22:04 pm by lovinthedeez »
Reply #1January 13, 2010, 06:49:31 pm
Re: Are all VE pumps like this?
« Reply #1 on: January 13, 2010, 06:49:31 pm »
love the roundies and red stripe gti bumper in the pic. the background really makes it look good.
Reply #2January 13, 2010, 07:00:15 pm
maxfax
  • 2126
« Reply #2 on: January 13, 2010, 07:00:15 pm »
Never noticed any stampings myself.. Even with having a dial indicator I rarely use it for timing, I guess my ears still work okay..  After adjusting mine to run and start properly I checked to see where it was..  It's rather pleased to be at 1.02mm.. It's also an '81...
Reply #3January 14, 2010, 08:02:12 am
lovinthedeez
  • 489
« Reply #3 on: January 14, 2010, 08:02:12 am »
bear camp road heading towards your way.  I'll take a picture of the stamping next time i'm under there.
Reply #4January 14, 2010, 09:56:30 am
« Reply #4 on: January 14, 2010, 09:56:30 am »
never heard of bear camp road. but it looks like a cool spot...
Reply #5January 14, 2010, 01:26:55 pm
wolf_walker
  • 1205
« Reply #5 on: January 14, 2010, 01:26:55 pm »
Using cold start lever?  Shouldn't need it unless it's freezing really with timing in the .9 region in my experience, but in the .8's it can be rough cold without.
Never seen stamps either.  If it was me I'd start with verifing TDC on the crank, then loosen the cam and make sure it's right, etc, etc, then try it again.
But I'm sorta OCD.
Mentat Text Two
Reply #6January 14, 2010, 01:37:59 pm
« Reply #6 on: January 14, 2010, 01:37:59 pm »
My 91 pump on my 81 engine loves it at 1.03mm as well :)
Reply #7January 18, 2010, 10:07:08 am
lovinthedeez
  • 489
« Reply #7 on: January 18, 2010, 10:07:08 am »
Reply #8January 18, 2010, 04:45:13 pm
« Reply #8 on: January 18, 2010, 04:45:13 pm »
the pump on my 1.5 has those markings there. just cant remember what the numbers were.
Reply #9January 18, 2010, 07:08:40 pm
wolf_walker
  • 1205
« Reply #9 on: January 18, 2010, 07:08:40 pm »
Ohh thaaat mark.  Mine has em, 1xx and 095.  No idea what they indicate, some calibration when it's built I assume.
Mentat Text Two
