Author Topic: WTB: downpipe and cat for 96 Passat TDI  (Read 3826 times)
December 20, 2009, 11:48:48 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« on: December 20, 2009, 11:48:48 am »
I am going to have to replace the downpipe and cat on the GF's 96 Passat TDI at some point. Does anyone have a GOOD one left over from a part out or know of an economical aftermarket solution? I know these things are oddballs with the 5th injector, I have disabled that by blocking off the fuel line that feeds it. Aren't these cats prone to cracking at the inlet? Should I be looking for a different setup? Any comments are appreciated.
thanks in advance... ;D
« Last Edit: December 20, 2009, 12:13:44 pm by ilikevwdiesel »
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #1December 21, 2009, 11:00:10 pm
caddywompus
  • 27
    • http://www.greaseworks.org
Re: WTB: downpipe and cat for 96 Passat TDI
« Reply #1 on: December 21, 2009, 11:00:10 pm »
IIRC I have a good B4 cat left over from a Vanagon TDI conversion.  It is cut just after the turbo flange, so it will have to be welded on at both ends.  If you're interested you can have it for $50 + S/H.
thx,
justin
82 Vanagon Westphalia 1.9TDI (1Z)
96 Passat Wagon 1.9 TDI
Reply #2December 22, 2009, 06:14:16 am
ilikevwdiesel
  • 1202
« Reply #2 on: December 22, 2009, 06:14:16 am »
I searched for downpipes online, found one at TDiparts.com that looks pretty good. I need a complete unit as I don't have a welder.
thanks anyways...
My Bio
Reply #3December 22, 2009, 09:19:36 am
GEE-BEE
  • 1604
« Reply #3 on: December 22, 2009, 09:19:36 am »
streettoys2000.com has some and a few kit's to make your own also..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
