Author Topic: lift a 90 Jetta  (Read 9343 times)
Reply #15December 15, 2009, 04:33:58 pm
Re: lift a 90 Jetta
« Reply #15 on: December 15, 2009, 04:33:58 pm »
did it finally just rust away? or did someone hit you and total it?
Reply #16December 15, 2009, 06:24:43 pm
truckinwagen
  • 1895
Re: lift a 90 Jetta
« Reply #16 on: December 15, 2009, 06:24:43 pm »
well, I got in an accident, which totaled it, but it was still drivable, so I did for almost a year.
the shell was plagued with rust so it was scrapped in favor of a red two door shell, but engine problems kept the new shell off the road for over a year, and it was crushed in the end under pressure from the city of Anchorage.
I saved all the worthwhile stuff off of it, which went into the supercharger motor build soon to be installed in the 85 GTI I replaced the red car with.
pics of the damage, swap into the red car, and the poor red rabbit that saw one mile of road.
83 Opel Kadett Diesel
Reply #17December 15, 2009, 07:56:16 pm
rabbitman
  • 2788
Re: lift a 90 Jetta
« Reply #17 on: December 15, 2009, 07:56:16 pm »
I hate it when city's make people get rid of stuff, what business is it of there's? >:(
Reply #18December 16, 2009, 06:58:49 am
trev
  • 67
Re: lift a 90 Jetta
« Reply #18 on: December 16, 2009, 06:58:49 am »
With the huge lift from the springs, did you have to monkey around with the drive axles?
Cheers
  Trev
Reply #19December 16, 2009, 12:56:03 pm
Re: lift a 90 Jetta
« Reply #19 on: December 16, 2009, 12:56:03 pm »
he still had the stock suspension limits. im sure he didnt use different struts or anything. the bump stops are built into the struts. i bet the axles worked just fine.
Reply #20December 16, 2009, 02:47:50 pm
truckinwagen
  • 1895
Re: lift a 90 Jetta
« Reply #20 on: December 16, 2009, 02:47:50 pm »
yep, stock struts, so the full droop was the same as stock, which is as far as you can go without having your axle hit the frame horn.
Reply #21December 17, 2009, 09:48:49 am
Re: lift a 90 Jetta
« Reply #21 on: December 17, 2009, 09:48:49 am »
thats really cool, i think i need to take and do that with my rabbit. ive always wanted a hunting rabbit, just need more ground clearance. so, i guess you could call it "wabbit hunting" then.
Reply #22December 19, 2009, 04:43:25 am
veector
  • 95
Re: lift a 90 Jetta
« Reply #22 on: December 19, 2009, 04:43:25 am »
This is passat wagon 16v suspension
1981 Jetta D
1997 Jetta TD
Reply #23December 19, 2009, 06:55:54 am
Re: lift a 90 Jetta
« Reply #23 on: December 19, 2009, 06:55:54 am »
Veector, new or used? Struts/shocks and springs or just springs? Is that freshly installed or after it's had time to settle?
Reply #24December 24, 2009, 07:34:45 am
Re: lift a 90 Jetta
« Reply #24 on: December 24, 2009, 07:34:45 am »
Veector, that looks swell. I love the height!!
Reply #25December 25, 2009, 10:32:28 am
Re: lift a 90 Jetta
« Reply #25 on: December 25, 2009, 10:32:28 am »
so, how does it do offroad? it looks like its been wheelin a time or 2. ive had mud clear up past the windows on my rabbit. and i dont mean a little mud, i mean you couldnt tell what color it was underneath the mud.
Reply #26January 13, 2010, 07:39:32 am
veector
  • 95
Re: lift a 90 Jetta
« Reply #26 on: January 13, 2010, 07:39:32 am »
Now its settled a bit so the front is a bit lower but the rear is still up in the air like that.  Its good offroad never gotten stuck but I dont push my luck too much.  The real fun is in deep snow!
1981 Jetta D
1997 Jetta TD
Reply #27January 18, 2010, 12:22:26 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Re: lift a 90 Jetta
« Reply #27 on: January 18, 2010, 12:22:26 pm »
I didn't read the whole thread but i've lifted by jetta quite a lot by adding a big nylon spacer ontop of the springs and riding on much bigger tires. 195/65/r15.
the nylon/plastic thing is just like hockey rink material and comes in big ... rolls? of it. You just cut the length to the desired lift and drill a hole the size of the strut plunger thing and drop it down onto the spring.
Ed
Reply #28February 12, 2010, 05:24:15 pm
ozzie
  • 25
Re: lift a 90 Jetta
« Reply #28 on: February 12, 2010, 05:24:15 pm »
I brought up the back of my 90 jetta an inch or 2 by doubling up the spring seat on the shock (hope that is what it is called - you know, the bottom plate that the spring sits in)
i have a buddy that has 3 on each side.  just a thought
oz
Reply #29February 17, 2010, 10:24:04 pm
Kantdrivefast
  • 196
Re: lift a 90 Jetta
« Reply #29 on: February 17, 2010, 10:24:04 pm »
