Author Topic: Turbo noise  (Read 3885 times)
November 13, 2009, 08:52:48 am
dennis
  • 311
Turbo noise
« on: November 13, 2009, 08:52:48 am »
My 240 Volvo wagon makes a noise that sounds like turbo whine, but is NA. Goes away when you let off the throttle. Pitch change with throttle change. Pretty strange. I though it was noise from the radio at first, but does not go away when the radio is off. It is a d24 engine which is the same as a VW 1.6 but with two extra cylinders.   ???
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #1November 13, 2009, 06:43:47 pm
Syncroincity
  • 727
Re: Turbo noise
« Reply #1 on: November 13, 2009, 06:43:47 pm »
Pitch changes with engine speed, or throttle position?
I'd check your belt covers first, make sure nothing's rubbing, or come loose.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #2November 14, 2009, 10:10:44 am
Re: Turbo noise
« Reply #2 on: November 14, 2009, 10:10:44 am »
I'll take a guess at a restrictive exhaust coupled with a pin hole leak near the manifold
Reply #3November 16, 2009, 06:23:39 am
dennis
  • 311
Re: Turbo noise
« Reply #3 on: November 16, 2009, 06:23:39 am »
Throttle position. Mostly from part load to ful load. If I completely let off the throttle the noise stops.
Reply #4November 16, 2009, 06:30:52 am
dennis
  • 311
Re: Turbo noise
« Reply #4 on: November 16, 2009, 06:30:52 am »
Thats a thought. Actually planning a turbo engine later, so a bigger exhaust would not be in vain.
