Author Topic: anyone know what an ALH should be timed to?  (Read 3540 times)
October 07, 2009, 06:13:00 am
oldskool rich
  • 446
« on: October 07, 2009, 06:13:00 am »
is it gona be 1mm? or isnt it important because of the knock sensor?
f6squared I.D.S.T
Reply #1October 07, 2009, 06:29:43 pm
diesel smoke
  • 209
Re: anyone know what an ALH should be timed to?
« Reply #1 on: October 07, 2009, 06:29:43 pm »
ALH timing is set with VAG-COM. And there isn't a knock sensor either.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #2October 07, 2009, 06:35:58 pm
oldskool rich
  • 446
« Reply #2 on: October 07, 2009, 06:35:58 pm »
whats the 3rd injector about then? the pump piston must be at a certain depth at TDC does anyone know what it is? what is it on a 1Z? its probly the same
f6squared I.D.S.T
Reply #3October 07, 2009, 06:41:51 pm
  • 3255
    • My collection of HOWTOs
« Reply #3 on: October 07, 2009, 06:41:51 pm »
It's a needle lift sensor that tells the computer when start of injection has occurred, which is fed back to the ECU as one of the many feedback loops.
As far as I know there's no published piston depth at TDC... best bet is to find someone with VAG COM and do er right.
Reply #4October 07, 2009, 07:08:21 pm
diesel smoke
  • 209
« Reply #4 on: October 07, 2009, 07:08:21 pm »
^^^ What he said.
OH! Vince, I need to return your tools! I'm forgetful sometimes... :-[
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #5October 09, 2009, 03:30:24 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #5 on: October 09, 2009, 03:30:24 pm »
I agree 100%
