AAZ Head Question
Topic: AAZ Head Question (Read 2355 times)
August 18, 2009, 08:38:32 pm
stomperz71
AAZ Head Question
August 18, 2009, 08:38:32 pm »
I'm in the process of rebuilding my 1.9 AAZ engine. When stripping the head down 2 of the lifters(I have hydraulic lifters)won't come out. They seem to stuck in one spot like their not floating in the bore. They move up/down but won't spin. Whats the best way to get them out? What would of caused this to happen?
Thanks
August 19, 2009, 08:04:36 pm
Syncroincity
Re: AAZ Head Question
August 19, 2009, 08:04:36 pm »
I took out one of mine that was sticky with a strong magnet and lots of Kroil... work it around alot, they will give up, they're sort of hydro-locked in the bore sometimes
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
August 19, 2009, 10:23:57 pm
stomperz71
August 19, 2009, 10:23:57 pm »
I tried that until I was blue!!
I was thinking next to just weld a nut on top and slide hammer it out. I know themn I would have to get new lifters. But I'm out of ideas???
August 20, 2009, 12:46:03 pm
macka
August 20, 2009, 12:46:03 pm »
drill a small hole in them, and put in a self tapping screw, then use the slide hammer
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
August 21, 2009, 12:47:24 am
stomperz71
August 21, 2009, 12:47:24 am »
Either way it would be junk afterwards, right?
August 21, 2009, 05:41:59 am
myke_w
August 21, 2009, 05:41:59 am »
It's possible the valves contacted the pistons and mushroomed the lifters, and that's why they're stuck, the only way you can tell if it's junk is to take them out and examine the bore.
August 21, 2009, 01:36:09 pm
stomperz71
August 21, 2009, 01:36:09 pm »
That could be the case, I bought the engine with a broken timing belt. I know theirs one bent valve, could be others just can't tell. The pistons all looked OK.
August 21, 2009, 01:42:27 pm
myke_w
August 21, 2009, 01:42:27 pm »
I've seen plenty of IDI's with broken belts and nice looking pistons, generally thery are still usable unless they have major damage.
You might try heating around the bore with a torch while holding the head upside down.
I'd recommend replacing all lifters if you broke a belt on the motor too.
AAZ Head Question
