General Information
Troubleshooting
Low speed surging - updated
4
5
Topic: Low speed surging - updated (Read 19674 times)
August 11, 2009, 04:00:45 am
stewardc
August 11, 2009, 04:00:45 am »
I have a completely rebuilt AAZ with a Giles pump. Often, at slow speeds I get surging or Jerking which I can only fix be stepping down hard on the throttle. My old 1.6 TD, and an old AAZ in a Jetta, never had this issue, and it has me baffled. I've even replaced all the motor mounts in hopes of eliminating it, but to no avail. A friend also has a modded AAZ in a Rocco with the same issues. He says it is a result of all the modifications, and is a small price to pay for all the power. I agree, but it sure is annoying. I have contacted Giles, so I will keep you all updated on any suggestions.
Does anyone have any ideas or cures for this problem?
Last Edit: September 02, 2009, 05:06:19 pm by stewardc
August 11, 2009, 10:03:53 am
Re: Low speed surging
August 11, 2009, 10:03:53 am »
Have you talked to Giles about it?
August 11, 2009, 10:43:42 am
stewardc
August 11, 2009, 10:43:42 am »
Not yet. I haven't been able to get him.
August 11, 2009, 06:55:43 pm
August 11, 2009, 06:55:43 pm »
i think it has to do with the governor and how its modded. after getting the pump changed on my 1.6TD i noticed the same "surging" (more like the car was more jerky?) which wasn't there before with the old (leaky) pump. and the re-sealed pump had the governor mod... but it did have more power, and the power kept going right till the redline, which was cool but scary at times
i can't remember if adding the small lift pump helped though...
August 11, 2009, 07:47:30 pm
Jettage1
Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
August 11, 2009, 07:47:30 pm »
I am VERY interested to hear any answers to this question. My car has done exactly the same thing since I installed my Giles pump this year. Never did it at all with the stock pump. I don't particularly like it, but it's #3 on my list of driveability issues to resolve, so haven't pestered Giles about it yet. (#1 is cold start issues, #2 is smoke-tuning, in case you were wondering
If anyone has any solutions to the surging, I'm all ears!! (and it's not related to loose IP mounting bolts, either)
Steve
92 Jetta EcoDiesel
pumped by Giles...powered by Frybrid...functional by dumb luck
August 12, 2009, 06:34:34 am
stewardc
August 12, 2009, 06:34:34 am »
I've gotten hold of Giles and he's thinking it over. I'll share his findings later.
August 14, 2009, 03:12:56 pm
stewardc
August 14, 2009, 03:12:56 pm »
Changed all filters---still the same and getting worse.
August 16, 2009, 05:20:50 pm
stewardc
August 16, 2009, 05:20:50 pm »
Interesting happenings - I am getting desperate...it's getting worse. Last tank I added 6 oz. of Power Service (white bottle) instead of the recommended 3 oz. I also added 2 cups of ATF. Immediately, the surging is almost completely gone.
More to follow.
August 16, 2009, 06:11:57 pm
Jettage1
August 16, 2009, 06:11:57 pm »
that is indeed interesting. My surging has remained at about the same level since installing the pump - no better, no worse.
It will be informative to see if your surging stays gone, or returns after you've burned through the tank of fuel with the additives in it.
Steve
92 Jetta EcoDiesel
August 16, 2009, 07:53:31 pm
catlin_cava
August 16, 2009, 07:53:31 pm »
I think it may just be a sign with those pumps...Hold it to the floor
Catlin
2010 VW Golf City 2.0L "Hers"
August 19, 2009, 07:17:43 pm
August 19, 2009, 07:17:43 pm »
Sounds like you could have injector problems. Have you had them tested lately? (both opening pressures)
Reply #11
August 20, 2009, 07:34:19 am
stewardc
Reply #11 on:
August 20, 2009, 07:34:19 am »
PROBLEM SOLVED !!!!!;D
It is 100% fuel-related. The next tank I put in a different brand of fuel than I normally use, and added 3 oz of Stanadyne, at Gyles suggestion. No more problem. The surge is gone.
Reply #12
August 20, 2009, 11:13:44 am
Jettage1
Reply #12 on:
August 20, 2009, 11:13:44 am »
Good for you! Not so good for me
My problem has persisted through multiple tanks as well as on both diesel and SVO. (and I installed rebuilt TD injectors from Giles when I did the pump).
Steve
92 Jetta EcoDiesel
Reply #13
August 20, 2009, 11:34:56 am
stewardc
Reply #13 on:
August 20, 2009, 11:34:56 am »
Put additive in the fuel to boost the cetane rating. Multiple tanks of crappy fuel will never cure anything. Only Stanadyne for me from now on !
Reply #14
August 20, 2009, 12:01:28 pm
Jettage1
Reply #14 on:
August 20, 2009, 12:01:28 pm »
Is Stanadyne an auto parts store item? Course it still begs the question of why the car ran fine with a stock pump but surges & possibly requires this additive with the performance pump...
Steve
92 Jetta EcoDiesel
4
5
General Information
Troubleshooting
