Author Topic: Advice for disabling my DRL's  (Read 10516 times)
April 11, 2009, 12:33:54 pm
ALVW3
« on: April 11, 2009, 12:33:54 pm »
Hi,
Sorry if this has been asked before ... I've got a 1990 VW Jetta Turbo Diesel, and I'd like to be able to disable the DRL's (I actually don't mind driving with them on, I just want the option, especially now since I'm having some charging issues and don't have time to diagnose the problem).
So my car is "Canadian", and I think that 1990 was the first year they made DRL's mandatory here. The headlight switch has a "TFL" connector, but the receptacle has no wire going to it so it is not in use (tried covering it anyway with no effect).
I actually found the wiring diagram in Bentley's for Daytime driving lights (Canada only) 1990 Jetta (Jan 1990 on) - mine was made in July. Unfortunately I'm not good at figuring out anything more than basic electrical issues.
Would anyone here have gone through this already and have a quick answer?
Thanks - Rob C
Reply #1April 11, 2009, 01:53:15 pm
« Reply #1 on: April 11, 2009, 01:53:15 pm »
On the firewall near the glowplug fuse there is a yellow wire with a connector. Disconnect that and your headlights will not come on with the DRLs.
Reply #2April 11, 2009, 02:31:40 pm
  • 1739
« Reply #2 on: April 11, 2009, 02:31:40 pm »
Damn Tyler, you beat me to the answer.
Reply #3April 11, 2009, 08:10:22 pm
ALVW3
« Reply #3 on: April 11, 2009, 08:10:22 pm »
Thanks for the advice guys. Maybe I'm blind, but I'm not seeing the yellow wire.
It looks like from the various wiring diagrams that the Canadian MK2 DRL wiring setup had 3 incarnations: up to Jan 1990, Jan 1990 to Aug 1990, then 1991-1992. Mine falls into the second category.
Reply #4April 12, 2009, 06:15:46 am
« Reply #4 on: April 12, 2009, 06:15:46 am »
Wow your car looks clean. Just have a look all along the rain tray and you should see it. It's the only single yellow wire up there.
Reply #5April 12, 2009, 07:46:29 am
  • 1739
« Reply #5 on: April 12, 2009, 07:46:29 am »
It' s possible it's all wrapped up above the fuse box. it should be pretty obvious, it like 5 ft of wire.
Reply #6September 24, 2009, 07:11:10 pm
hippiekiller
  • 73
Re: Advice for disabling my DRL's
« Reply #6 on: September 24, 2009, 07:11:10 pm »
What about on an mk3 jetta, is there a similiar method? (I'm pretty sure there is no yellow wire....)
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #7September 24, 2009, 09:50:47 pm
  • 3255
    • My collection of HOWTOs
« Reply #7 on: September 24, 2009, 09:50:47 pm »
The professional engineer in me is duty-bound to remind the Canadians in the group that DRLs are required by law on Canada in all vehicles so equipped by the factory... which makes disabling them on cars so equipped unlawful.
* * *end of public service announcement * * *
...as you were, boys   ;)
Reply #8September 25, 2009, 01:12:49 pm
macka
  • 957
« Reply #8 on: September 25, 2009, 01:12:49 pm »
Just so you know the mounties love writing tickets, and will pull you over if they suspect they might be giving you a 2500 dollar dummie award.
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #9September 25, 2009, 07:39:26 pm
hippiekiller
  • 73
« Reply #9 on: September 25, 2009, 07:39:26 pm »
It would be nice if there was a simple fix, the kind of thing one could redo on the spot and say.."oh its just the fuse...."when the coppers start askin questions...it just kinda burns me to run my kinda pricey 80/100W relay'd bulbs all the time...it definitely seems to burn them out quicker when they're gettin 13 volts ;D..
95 jetta, 2"lift
Reply #10September 25, 2009, 08:17:33 pm
  • 3255
« Reply #10 on: September 25, 2009, 08:17:33 pm »
Some day I'm gonna have the time to design a relayed headlight system with DRLs... my idea is to run the low beams in series for DRL, parallel like normal at night.  Bulbs should last forever.  ;)
Reply #11September 28, 2009, 01:52:14 am
Op-Ivy
  • 513
« Reply #11 on: September 28, 2009, 01:52:14 am »
Easiest way to disable daytime running lights: Bend the "TFL" pin in your headlight switch down so it doesn't make contact. Works on mk2's, 3's and 4's!
Bend it and don't cut it in case you ever want to go back to DRL's.
Reply #12November 01, 2016, 06:39:18 pm
binoo
  • 2
« Reply #12 on: November 01, 2016, 06:39:18 pm »
REVIVE!!!
I just got my 1991 VW Jetta TD.  I was sitting in park (engine off), and key turned once.  problem is that all the lights come on, is there no acc mode on this car? or is that the crappy DRL lights ??
I don't care about the daytime running lights being on when I'm driving, but i'd like to be able to only keep my radio on when I'm parked with the engine shut off.
please help!  thanks!!!
Reply #13November 01, 2016, 08:58:51 pm
« Reply #13 on: November 01, 2016, 08:58:51 pm »
And what is wrong with wiring something off the fuse box that is 12 volt on and just turning it on when you want it on?  Rather than tied to a key position?  Least draw on the battery I can think of.
Reply #14November 03, 2016, 08:16:55 am
« Reply #14 on: November 03, 2016, 08:16:55 am »
With the 4 different VW's I've had you could simply turn the key on and then off to have the radio on.  The radio stays powered till you physically remove the key. I was pretty sure the Mk2 used the same setup?
