Borg Warner BV50 Turbo Specs??
Topic: Borg Warner BV50 Turbo Specs?? (Read 8433 times)
April 07, 2009, 11:41:27 pm
barrygti
April 07, 2009, 11:41:27 pm »
Does anyone have a cpmpressor map for BV50 VNT turbos?
I have 2 of them from Land Rover TDV6 engines, they run around 190bhp and 340lb/ft on the 2.7 V6 diesel. Believe it is also called a K04BV???
What do we think on a 1.6 bottom end/1.9 head engine?
April 08, 2009, 05:39:18 am
subsonic
April 08, 2009, 05:39:18 am »
Not sure if this will help. It has some more info that migt help you find the map:
http://www.arturbo.co.uk/catalogue_turbos.asp?Make=18
April 09, 2009, 08:03:51 pm
barrygti
April 09, 2009, 08:03:51 pm »
Thanks, I have tried EVERYWHERE and can't find any info, so f*ck it I will just use it and hope it runs ok on a little 1.6 engine with my ported 1.9 head..
If not I will revert to the standard 1.6 turbo.
April 09, 2009, 08:06:30 pm
subsonic
April 09, 2009, 08:06:30 pm »
What are the numbers off the ID tag?
April 09, 2009, 08:17:45 pm
barrygti
April 09, 2009, 08:17:45 pm »
Ok here goes:
I.D. Tag
Groess - 4H20 6K682 CG
Lader - 1A 50091159 00036
Ausf - 53049700065
On inlet housing
53041015196
on Exhaust housing
53041013569
B 4.5 - 0.6
KPE15K11
April 09, 2009, 08:23:29 pm
barrygti
April 09, 2009, 08:23:29 pm »
Only this one shows up anything and just tells me what I already know, it's from a Land Rover TDV6
53049700065
April 11, 2009, 08:35:07 am
subsonic
April 11, 2009, 08:35:07 am »
Check out this link. There is a guy who is running the same turbo. Perhaps you can get in touch with him. Good luck. Jim
http://forums.tdiclub.com/showthread.php?t=201181
April 11, 2009, 12:53:21 pm
barrygti
April 11, 2009, 12:53:21 pm »
Thanks, I will join up and get in touch with him!!
