For Sale/Looking For
Parts for Sale/Wanted
Who needs "hot" injection?
Topic: Who needs "hot" injection? (Read 5972 times)
April 05, 2009, 06:44:10 pm
dillenger1
April 05, 2009, 06:44:10 pm »
Im selling my 10mm hybrid pump.runs real strong.Peugoet hybrid with volkswagen core.Make an offer
altitude pump is good never ran it,but has new seals .all is well inside.make offer Has governor mod done
the hybrid
the fuel pin on the alt comp pump
1.6td in toyota pickup
10mm head ,t3 intercooled.
April 08, 2009, 05:33:58 pm
dillenger1
April 08, 2009, 05:33:58 pm »
bump.Nobody needs a good injection pump?The altitude pump has the governor mod done
April 08, 2009, 05:38:25 pm
truckinwagen
April 08, 2009, 05:38:25 pm »
what kind of price range you looking at getting?
what shaft does it have?
is it just an altitude comp, or has it been converted to run boost enrichment?
83 Opel Kadett Diesel
April 09, 2009, 03:05:49 am
dillenger1
April 09, 2009, 03:05:49 am »
Its been converted to run off boost.It needs a stiffer spring in the aneroid though.Ill take 125.00 for the altitude pump and 175.00 for the 10mm
April 09, 2009, 01:38:00 pm
April 09, 2009, 01:38:00 pm »
you built this pump right? how well did it fuel your engine? what injectors is it set up to run best with?
April 10, 2009, 03:20:04 am
dillenger1
April 10, 2009, 03:20:04 am »
Yep i put it together.It fueled my engine quite well .I was running gtd nozzles
April 10, 2009, 09:25:21 am
April 10, 2009, 09:25:21 am »
would it run good with a set of fresh TD 155bar injectors? or is there something better about the GTD nozzles?
April 10, 2009, 04:27:18 pm
dillenger1
April 10, 2009, 04:27:18 pm »
Sure.I dont think the gtd nozzles actually flow more fuel though.So any factory nozzle would work.I have the injectors to brand new nozzles just poptested and adjusted to 160 bar.
April 18, 2009, 02:52:06 pm
dillenger1
April 18, 2009, 02:52:06 pm »
who needs a pump or two?
May 03, 2009, 01:42:09 am
ryanp
May 03, 2009, 01:42:09 am »
dillenger1 - just a quick question, I've got a new peugeot pump coming my way, would this fit directly onto an AAZ without building it into a VW casing?
Cheers
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
May 08, 2009, 04:09:46 am
dieselherb1
May 08, 2009, 04:09:46 am »
Bump
Price now?
Reply #11
May 08, 2009, 07:54:41 am
myke_w
Reply #11 on:
May 08, 2009, 07:54:41 am »
was this built to run an MTDI?
Reply #12
May 08, 2009, 10:22:50 am
Reply #12 on:
May 08, 2009, 10:22:50 am »
no, he built it to run on his 1.6 in his toyota.. think he told me he had it set up with 160 bar injectors or something..
Reply #13
May 26, 2009, 01:40:05 pm
myke_w
Re: Who needs "hot" injection?
Reply #13 on:
May 26, 2009, 01:40:05 pm »
Does the 10mm have the lda?
