Author Topic: Rought Idle  (Read 2445 times)
April 01, 2009, 04:15:19 am
catlin_cava
  • 1954
Rought Idle
« on: April 01, 2009, 04:15:19 am »
I can't seem to get teh idle set on the motor, its idling around 1400RPM,I tried the Idle set screw and its not working. And one more thing if the turbo has 3 Ks on it in a triangle what kind of turbo is it?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1April 01, 2009, 04:46:04 am
Rought Idle
« Reply #1 on: April 01, 2009, 04:46:04 am »
What motor do you have?
Reply #2April 01, 2009, 04:46:16 am
Dirtrag2
  • 298
Rought Idle
« Reply #2 on: April 01, 2009, 04:46:16 am »
did you turn the fueling up or are you still at stock settings?
the turbo is a K03, good for about 15psi if you turn the wastegate bolt to the outer end of the adjustment  :wink:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #3April 01, 2009, 04:53:42 am
catlin_cava
  • 1954
Rought Idle
« Reply #3 on: April 01, 2009, 04:53:42 am »
1.9AAZ, and i thing the owner said he turned the fuel up. and where is the waste gate so I can fix it :twisted:
Catlin
Reply #4April 01, 2009, 05:08:21 am
Dirtrag2
  • 298
Rought Idle
« Reply #4 on: April 01, 2009, 05:08:21 am »
if fueling was turned up, the residual fuel screw may need to be turned down.  it's the screw that acts like a stopper to the throttle spring setup.  use lots of WD-40 a couple of times a day or so ahead and it should turn.
the wastegate is just above the turbo near the firewall. there is a rectangular safety stopper over the assembly, just remove, unscrew the nuts and replace safety thingy so it all stays put.
...Darcy
Reply #5April 01, 2009, 08:45:34 am
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
Rought Idle
« Reply #5 on: April 01, 2009, 08:45:34 am »
i had bad idle and i ran injector cleaner through and it fixed it..
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #6April 01, 2009, 02:13:05 pm
catlin_cava
  • 1954
Rought Idle
« Reply #6 on: April 01, 2009, 02:13:05 pm »
Its still idling around 1200rpm, i tried setting the Idle screw and it seams to have no affect
Catlin
Reply #7April 01, 2009, 04:53:11 pm
Rought Idle
« Reply #7 on: April 01, 2009, 04:53:11 pm »
It could be a K14 as well.
The residual fuel screw (the one that the throttle rests on) is not the one you need to be turning. On the back of the pump either where the rod from the cold start or the cable from the vacuum pod is there is a lever with 2 screws and 2 10mm nuts.
If you have the vacuum pod you need to loosen the one that the lever is resting against with the cold start off.
If you have the rod you need to rotate the rod to adjust your idle.
You could just have bad injectors. When were they last rebuilt?
Reply #8April 01, 2009, 05:24:44 pm
catlin_cava
  • 1954
Rought Idle
« Reply #8 on: April 01, 2009, 05:24:44 pm »
i have no idea to be honest.
Catlin
