Author Topic: alternator draining battery  (Read 3779 times)
January 27, 2009, 03:03:46 pm
dillenger1
  • 777
« on: January 27, 2009, 03:03:46 pm »
My alternator drains when not running,but it still charges ok.does this happen when the brushes go bad?Will replacing them help?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1January 27, 2009, 05:10:50 pm
« Reply #1 on: January 27, 2009, 05:10:50 pm »
souds like a diode possibly?
Reply #2January 27, 2009, 05:36:55 pm
dillenger1
  • 777
« Reply #2 on: January 27, 2009, 05:36:55 pm »
Now the diode you speak of where is it located?
Reply #3January 27, 2009, 05:40:59 pm
« Reply #3 on: January 27, 2009, 05:40:59 pm »
Quote from: "dillenger1"
no idea.  but if it was broken in the 'open' position then it would allow electrons to flow in both directions, draining the battery.  it might be in the voltage regulator itself?
when you shut the car off, check the exciter wire for any voltage reading.  it shouldn't have any AFAIK.
Reply #4January 27, 2009, 09:45:21 pm
  • 1739
« Reply #4 on: January 27, 2009, 09:45:21 pm »
Some bosch alternators have removable  brushes and regulator. I don't remember if the diodes are with it,but i don't think so.
Reply #5January 28, 2009, 03:56:21 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: January 28, 2009, 03:56:21 am »
you 100% sure its the alternator that is draining the batt?
Ed
