Just to make sure I can boost hard.
Topic: Just to make sure I can boost hard. (Read 2095 times)
December 05, 2008, 01:36:27 pm
ObscuredByClouds
December 05, 2008, 01:36:27 pm »
Last Edit: December 30, 2011, 11:08:19 pm by ObscuredByClouds
December 05, 2008, 02:18:52 pm
December 05, 2008, 02:18:52 pm »
yeah fuel adjustments will change boost now, with a k24 i could get almost 30 psi like that, i wouldn't run that boost tho it takes alot of fuel and smoke, but i was young and dumb and liked playing with my car at the time. but i;m still young haha i just learned from a mistake.
December 05, 2008, 03:19:43 pm
ObscuredByClouds
December 05, 2008, 03:19:43 pm »
but without fuel adjustment I've seen most people run into about 14psi.. jw what my car will want to boost to when I run it.
December 05, 2008, 03:34:00 pm
Smokey Eddy
December 05, 2008, 03:34:00 pm »
Heeheee
I sawz that pic before all of yous did!
I JB'd mine. I did exactly what NoSurrenderAG did except i used the orig. parts.
I used anti-sieze for sealant incase i run into issues with needing a waste gate so i can just break the JB out of it later.
Ed
THROWN ROD
December 05, 2008, 04:13:59 pm
December 05, 2008, 04:13:59 pm »
mine did 15psi on the stock pump settings
December 05, 2008, 11:06:14 pm
December 05, 2008, 11:06:14 pm »
open the LDA cover and remove the boost pin (attached to the black rubber diaphram) and turn the starwheel i think clockwise for more travel. (or is it counter-clockwise? :lol:)
i put anti seize on the LDA bolts to make it easier to take off in the winter, and in general. plus i found that the aluminum was starting to corrode a bit. much like it does in the injector holes.
