General Information
Troubleshooting
Blower motor swapping
Topic: Blower motor swapping (Read 4793 times)
November 13, 2008, 09:22:24 pm
TDDrew
User+
November 13, 2008, 09:22:24 pm »
Does anybody know if I can use a "non-a/c" blower motor in my a/c equipt 79 Rabbit?
...blower motor is bad and I need a replacement and all I can find are "non-a/c".
Thanks in advance!
79 Rabbit 1.6 Diesel 4 door
79 Rabbit 1.5 Diesel 2 door- with a/c, oooooo.
November 13, 2008, 09:29:53 pm
Smokey Eddy
November 13, 2008, 09:29:53 pm »
uhhhhh
If by blower motor you mean a TD...
...nd by ac you mean it came from the factory with an ac bolted on there...
it makes absolutely no difference to the engine except for some electronics if it has AC. If you're removing the AC all that happens is you gain power and mileage.
what are you asking? I'm not sure i fully understand.
an engine with air conditioning means absolutely nothing. It's like saying "will an engine from a car without a radio work in a car that has a radio"
Ed
THROWN ROD
November 13, 2008, 10:24:04 pm
Dakotakid
November 13, 2008, 10:24:04 pm »
The blower motor for his heater.
November 14, 2008, 12:50:23 am
Smokey Eddy
November 14, 2008, 12:50:23 am »
OHHHHHHHHHHHHH!!!!!!!!!!!!
Learn new things everyday.
I was thinking blower as in another name for a turbo...
sheesh. What is the blower motor in the heater core?
the fan?
Ed
THROWN ROD
November 14, 2008, 03:20:31 am
clbanman
Cambridge, Ontario
November 14, 2008, 03:20:31 am »
Short answer: No. There is another thread on here somewhere about this same question that has pictures and explains the difference.
Calvin
91 VW Golf 1.6NA 5spd
November 14, 2008, 07:53:19 am
Possum79
November 14, 2008, 07:53:19 am »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=17051
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
November 14, 2008, 11:14:54 am
Dakotakid
November 14, 2008, 11:14:54 am »
Ya, but he is talking about a car MUCH older than these fans fit....'79 Rabbit....right??? O-L-D stuff.
November 14, 2008, 01:58:23 pm
smutts
ClackClackClackClackClack
November 14, 2008, 01:58:23 pm »
It's nearly always the same fault. Dry bearings lead to the speed control resistances overheating and blowing the thermal fuse. Cost of repair is usually a 70 pence (a dollar?) thermal fuse, a strategic 3mm hole drilled to give access to the hidden bearing, a few drops of gearbox oil and a couple of hours in on a winter evening. Unless it siezed solid on full speed and burnt the armature to death.
http://en.wikipedia.org/wiki/Magic_smoke
But this is a fix I've done on 7 cars (not all vw) so might be worth a punt. :twisted:
November 14, 2008, 03:40:41 pm
November 14, 2008, 03:40:41 pm »
Got ya covered!! :lol:
November 20, 2008, 12:50:45 pm
TDDrew
User+
November 20, 2008, 12:50:45 pm »
Yep, just to clarify, it's the blower fan/motor for the "climate system". My car has factory A/C, which is slowly being removed. The fan does not repond when it is power up, fuses are good, has power and ground at connectors. I can spin the cage by hand, but it has quite a bit of resistance. I will be doing the radiator soon, so I will pull the blower out then and tear it down to see if it is repairable.
Maybe someone has a non-a/c climate box assembly that I could swap in?
Thanks for the input fellas.
November 20, 2008, 08:04:47 pm
rabbitman
November 20, 2008, 08:04:47 pm »
I have a heater box but there's no doors in it and it's been "modified" from original.
http://www.partsgeek.com/catalog/1982/volkswagen/jetta/climate_control/blower_motor.html
Is the one on the bottom like the one you have? If it is then I have a new one I can part with since I don't have ac.
Reply #11
November 20, 2008, 09:04:53 pm
TDDrew
User+
Reply #11 on:
November 20, 2008, 09:04:53 pm »
I looked up my car on that site and it just comes up with non- a/c blower motors which are the same part nuber as the ones for your car. The only difference I can make out between the a/c blowers from the pic (assuming that is the actual pic) is the wiring harness. Matbe the motor it self is the same and I can just replace those pars........I wish there was a way to find out for sure. I'm going to do some more research. I will keep you in mind.
thanks!
General Information
Troubleshooting
