Author Topic: Torx  (Read 3409 times)
November 07, 2008, 03:04:44 pm
Kantdrive55
  • 65
    • http://www.dieselperformance.com
Torx
« on: November 07, 2008, 03:04:44 pm »
What size torx bit is it to take the head bolts out of a 1.9 AAZ?  Thanks
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
Reply #1November 07, 2008, 03:06:50 pm
Torx
« Reply #1 on: November 07, 2008, 03:06:50 pm »
12 point (triple square) 12mm bit
be sure to remove them in the proper sequence too
Reply #2November 07, 2008, 03:20:13 pm
Kantdrive55
  • 65
Torx
« Reply #2 on: November 07, 2008, 03:20:13 pm »
Thanks.
1993 TD Jetta
Reply #3November 07, 2008, 03:39:42 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Torx
« Reply #3 on: November 07, 2008, 03:39:42 pm »
I don't need mine anymore if you want mine?
(i got studs)
Ed
Reply #4November 07, 2008, 04:06:36 pm
Torx
« Reply #4 on: November 07, 2008, 04:06:36 pm »
Are they Prothe or real stuff?
Reply #5November 08, 2008, 05:28:27 pm
Kantdrive55
  • 65
Torx
« Reply #5 on: November 08, 2008, 05:28:27 pm »
Quote from: "Smokey Eddy"
(i got studs)
Sure I work at BD Power in Abby.  I am off at 4.  Send me a PM and I will drop by and grab it.  Thanks.
1993 TD Jetta
