General Information
General
will these wheels fit..
Topic: will these wheels fit.. (Read 5258 times)
October 30, 2008, 08:19:09 am
beew
User+
October 30, 2008, 08:19:09 am »
a 94 jetta td?
they are 13" vw
94 Jetta GL diesel
October 30, 2008, 08:31:04 am
blkboostedtruck
October 30, 2008, 08:31:04 am »
they should unless you have large brake rotors in front? what size rims you have on it now? if you have 13 on it now they will work ! other wise just try one and see if it clears the caliper?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
October 30, 2008, 08:42:53 am
beew
User+
October 30, 2008, 08:42:53 am »
i have 14s now and it has the smaller rotor..just wanted to make sure.. need some snows!
94 Jetta GL diesel
October 30, 2008, 10:14:39 am
Quantum TD
October 30, 2008, 10:14:39 am »
I don't think they'll work. As far as I know, all MKIII cars had the Girling calipers (10.1 inch). You can idenify them by the name embossed on the caliper itself, or the 2 guide pins the caliper will ride on.
If you have Girling calipers, these rims won't fit over them.
October 30, 2008, 11:23:48 am
Op-Ivy
October 30, 2008, 11:23:48 am »
For some reason as well I don't think 13's fit on mk3's. Try a search on vwvortex and you will probably come up with more info.
October 30, 2008, 02:44:51 pm
beew
User+
October 30, 2008, 02:44:51 pm »
i tried them and they were a large enough diameter to clear but the caliper hit the inside face of the rim
is 185/60/14 stock tire size on an mk3?
94 Jetta GL diesel
General Information
General
