Author Topic: aba exhaust manifold to 1.6L diesel, does it fit?  (Read 4523 times)
August 19, 2008, 11:42:17 am
voodoo
  • 65
    she thinks my tractor's sexy
« on: August 19, 2008, 11:42:17 am »
looking for the best flowing exhaust for  no turbo
Reply #1August 19, 2008, 11:47:20 am
blkboostedtruck
  • 1535
« Reply #1 on: August 19, 2008, 11:47:20 am »
header's would flow best!
tublar pipes
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 19, 2008, 04:22:37 pm
« Reply #2 on: August 19, 2008, 04:22:37 pm »
yes it fits, to the head anyways, might hit the intake a bit which would then require some grinding
Reply #3August 19, 2008, 09:46:38 pm
  • 2926
« Reply #3 on: August 19, 2008, 09:46:38 pm »
I have a 2.0 with the head off, sitting in my driveway.
 I'll try to get a look tomorrow.
 Since the intake is on the other side for an ABA; Burn might be right about the intake not fitting next to the exhaust.
Reply #4August 20, 2008, 06:39:42 am
flapjack
  • 283
« Reply #4 on: August 20, 2008, 06:39:42 am »
didn't hillfold use one of those flipped over?
signature
Reply #5August 20, 2008, 08:46:16 am
TedV
  • 182
« Reply #5 on: August 20, 2008, 08:46:16 am »
if you don't like the tubular header, how about the cast iron dual outlet manifold from a 1.6 gasser with a Techtonics downpipe, etc.  You didn't mention what chassis you are putting this on.  You can grind and weld most anything to fit.  :lol:    Cast iron manifolds are HEAVY tho.
tubular header = less weight = more power to weight ratio from same HP :wink:
Reply #6August 20, 2008, 10:35:47 am
voodoo
  • 65
« Reply #6 on: August 20, 2008, 10:35:47 am »
I have 3 different intakes and 3 different exhausts and am trying to find the best combination.
I will try the crossflow aba manifold later today, but it is still bolted to a motor. maybe I will post pictures when it is on a head.
I would go with a turbo but I am allergic to compressor wheel explosions.
Reply #7August 24, 2008, 12:37:23 am
  • 2926
« Reply #7 on: August 24, 2008, 12:37:23 am »
I took a look, set a head on it.
 The exhaust matches up but i couldn't set the intake in place and chack for clearance because of a piece of metal tubing that was in the way.
 It looks like there wil be plenty of clearance.
