Author Topic: auto diesel trans code #  (Read 6474 times)
August 18, 2008, 02:01:43 pm
blkboostedtruck
  • 1535
« on: August 18, 2008, 02:01:43 pm »
does anybody know what the trans code # for a diesel automatic transmission?
i bought one and would like to check the # so i know i got what i want!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #1August 18, 2008, 05:15:05 pm
« Reply #1 on: August 18, 2008, 05:15:05 pm »
tell me where to look and I'll check on mine
Reply #2August 18, 2008, 05:34:27 pm
blkboostedtruck
  • 1535
« Reply #2 on: August 18, 2008, 05:34:27 pm »
trans code is stamped on top on a ear near the top engine to trans bolt closest to the freeze plugs about where the heater core hose comes out to the firewall!
mine is stamped EQ with a few other # aswell
Duane
'66 variant 1500S
Reply #3August 18, 2008, 09:02:49 pm
Dakotakid
  • 1240
« Reply #3 on: August 18, 2008, 09:02:49 pm »
I've got one sitting out here in the shop. It is under a whole bunch of s**t. I'll dig it out tomorrow.
What are you going to put the auto in, anyway???
Reply #4August 18, 2008, 10:58:20 pm
blkboostedtruck
  • 1535
« Reply #4 on: August 18, 2008, 10:58:20 pm »
thanks
one of my caddy's! i'm old and gettin tired of shifting
Duane
'66 variant 1500S
Reply #5August 19, 2008, 10:30:21 am
Dakotakid
  • 1240
« Reply #5 on: August 19, 2008, 10:30:21 am »
All right........this was in my beloved '82 Jetta. Made it 435,000 miles and was JUST beginning to get slightly weak in reverse. I pulled the pan and switched ATF every 5,000 miles.
Has trans code and date of manufacture: TO 03052
Let me know if you want the trans for any reason. It is waiting to go to heaven.
Reply #6August 19, 2008, 11:13:37 am
blkboostedtruck
  • 1535
« Reply #6 on: August 19, 2008, 11:13:37 am »
did your tranny origanlly come from a gasser or a diesel?
the diesel's auto trans have a free wheeling feature when you let off tha gas pedal
so i'm hopping the one i bought is a diesel auto trans with code EQ
this trans did come out of a MK2 i'm hoping someone out there that has a known diesel auto trans can confirm that i got what i wanted!
if you got a diesel auto trans Dakota hang on to it thier getting hard to find!
Duane
'66 variant 1500S
Reply #7August 19, 2008, 09:55:38 pm
Dakotakid
  • 1240
« Reply #7 on: August 19, 2008, 09:55:38 pm »
Yes, this TO code trans was a real live diesel trans that kicked out and went to sleep when you let off the pedal.
Actually, that annoyed the hell out of me and I set the throttle cable to keep it in all the time. I have this habit of saving auto clutches and I slipped it in neutral all the time on my own.
That kick-out is annoying as it kicks out when you really don't want it to and then you get this lag and re-engagement that looks cool on paper but bites in reality.
This Jetta came out of Virginia Beach, Virginia and I acquired it in Dallas when I was interning down there. Only had 52,000 miles on it. I proceeded to go almost 400,000 more. THAT German engine was the longest-lasting engine I ever had. It's still sitting here on the concrete.
But yes, TO is all diesel genetics!
Reply #8August 20, 2008, 12:04:37 pm
blkboostedtruck
  • 1535
« Reply #8 on: August 20, 2008, 12:04:37 pm »
now i'm really not sure what? i got i found this one on samba
looks like code begining with (T) is a defanet diesel trans
anybody know where i can check codes for automatics
or have one that has the same code as mine that is a diesel?
thanks Duane
http://www.thesamba.com/vw/classifieds/detail.php?id=477489
'66 variant 1500S
Reply #9August 20, 2008, 01:38:06 pm
« Reply #9 on: August 20, 2008, 01:38:06 pm »
I would about kill for a auto trans..
If only they were at least a 4spd.
Reply #10August 20, 2008, 02:42:53 pm
Dakotakid
  • 1240
« Reply #10 on: August 20, 2008, 02:42:53 pm »
I don't see the governor on that one. Maybe it's behind those hoses?
Every now and then, on a really hot day the vent would apparently stick shut and then reopen with a vengence. Then, it would not do it for 20,000 miles.
I remember the engine bay covered in pink on a 100 degree day in the rolling hills of Kansas :shock:!!!!!!!
