Author Topic: Cam seal=groves worn into my cam=??  (Read 2369 times)
August 15, 2008, 04:33:51 pm
53 willys
« on: August 15, 2008, 04:33:51 pm »
yeah I am taking my head apart today and I see that the cam seal has worn two diffreant groves into the cam...is this ok? normal? if not whats the best way to fix it??
can a machine shop fix the issue?? or would I need to buy a new cam or??????
thanks 8)
Reply #1August 15, 2008, 04:39:20 pm
« Reply #1 on: August 15, 2008, 04:39:20 pm »
Depends on if it's leaking or not. If not, I'd just fit a new seal. If it is, a machine shop can pot a speedy sleeve on.
Reply #2August 15, 2008, 06:00:15 pm
53 willys
« Reply #2 on: August 15, 2008, 06:00:15 pm »
yeah I dont really know if it was leaking???
when I got this engine it looked like everything had been leaking on it!! lol
...I guess I will just ask the machine shop what they think...
Reply #3August 16, 2008, 08:15:18 pm
« Reply #3 on: August 16, 2008, 08:15:18 pm »
Worst case I probably have another cam for ya.
Reply #4August 17, 2008, 06:40:02 am
53 willys
« Reply #4 on: August 17, 2008, 06:40:02 am »
Quote from: "zukgod1"
thanks Dan I will just put it together for now and see if it does leak...
thanks to you and this forum for all the help and advice you give.
 8)
Reply #5August 17, 2008, 11:42:07 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: August 17, 2008, 11:42:07 am »
If you got it and it's filthy as hell it probably does leak from the cam because its the highest and most likely point to leak copious amounts of oil. I tried to reuse a broken cork gasket once with heaps of RTV it sorta worked but it still made a huge mess. Get a rubber gasket if you can, i recomend it!
Ed
