General Information
Troubleshooting
Transmission Locked in Reverse - Suspect Speedometer Gear
Topic: Transmission Locked in Reverse - Suspect Speedometer Gear (Read 4386 times)
June 12, 2008, 08:30:38 pm
jlw
Newbie
June 12, 2008, 08:30:38 pm »
1985 Golf 1.6 NA 5 speed:
I replaced the speedometer cable and noticed that the gear didn't come out with the old cable. I thought I got the new cable installed but I THINK the gear must not have engaged with the new cable end.
I drove the car but no speedo action. Today I backed out and the trans/shifter is jammed in reverse.
I can't even see the gear inside the trans. I've felt around and can't feel the gear either.
Is it possible that this gear is causing the problem?
Does anyone know the insides of these 5 speeds well enough to tell me if I have a chance at fixing it without removing the transmission and tearing it all apart?
1985 Golf Diesel (work in progress)
2003 Kawasaki ZRX1200R
June 18, 2008, 04:26:15 pm
June 18, 2008, 04:26:15 pm »
www.brokevw.com
June 18, 2008, 07:09:03 pm
jlw
Newbie
Thanks
June 18, 2008, 07:09:03 pm »
I've sent a request for advice to the BrokeVW.com person.
June 19, 2008, 11:22:29 am
jlw
Newbie
Just got a response from Brian @ BrokeVW.com
June 19, 2008, 11:22:29 am »
Brian at
http://www.BrokeVW.com
said that the speedo gear can and often does get knocked off and end up causing reverse gear problems. Here's Brians reply for anyone who may be following this post:
Jeff --
Before I opened the email, I planned to ask about any recent speedo gear problems based on just the subject line.
It is, without question, why the trans is stuck in reverse. The chunk of plastic speedo gear has sunk and settled to the lowest point in the trans, right where the reverse idler gear slides.
They either get locked into or out of reverse gear. Sometimes years go by with no problems, sometimes it happens fairly quickly.
There is no easy way to remove it, I'm afraid. You can drain the fluid, use a flexible claw grabber tool, and go fishing, but if it can't be removed, the trans would need split open to get the gear out.
The problem with leaving them in, besides the reverse idler issue, is that the chunks of plastic as the gear is mangled inside can get into the sync key slots, get into the oil passage that feeds the front input shaft bearing, and can cause bearing rollers to slide and skip instead of roll.
Let me know if there is anything else I can help with, or if you need the trans worked on.
Brian
June 19, 2008, 09:42:43 pm
Op-Ivy
June 19, 2008, 09:42:43 pm »
Nice of him to send you a nice little blurb so quickly. Looks like you're going fishing! Good luck!
June 20, 2008, 09:04:54 am
jlw
Newbie
Motor & Trans is coming out
June 20, 2008, 09:04:54 am »
Tomorrow I'll be pulling the engine and trans. I'll take the opportunity to re-gasket the engine externals, do the timing belt and tensioner thing and maybe water pump.
Then I'll see if I can see/fish the gear out. I imagine the trans will need to come apart. I'll have to make a decision as to whether I do it or send it out for someone else to split the cases.
~Jeff
General Information
Troubleshooting
