Author Topic: frig-shnoitz (help)  (Read 2398 times)
May 24, 2008, 02:44:20 pm
smoken u
  • 231
frig-shnoitz (help)
« on: May 24, 2008, 02:44:20 pm »
HI all. after performing the BOV disable mod, and turning the max fuel screw up 1 turn, I still am only at 10 PSI of boost. :?
What went wrong?, can anyone give me advice or help?
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1May 24, 2008, 03:01:27 pm
  • 5104
frig-shnoitz (help)
« Reply #1 on: May 24, 2008, 03:01:27 pm »
you need to adjust your wastegate, which turbo do you have?
Reply #2May 24, 2008, 03:10:26 pm
smoken u
  • 231
frig-shnoitz (help)
« Reply #2 on: May 24, 2008, 03:10:26 pm »
I'VE GOT A k-14  old style wastegate.
How do you adjust it? I'm not quite sure.
Reply #3May 24, 2008, 03:11:37 pm
  • 5104
frig-shnoitz (help)
« Reply #3 on: May 24, 2008, 03:11:37 pm »
ok u need a deep well 10mm, use that to loosen the lock nut on the top of the wastegate can, then u need a 3mm allen wrench to adjust the stud on the wastegate
Reply #4May 24, 2008, 03:17:42 pm
smoken u
  • 231
frig-shnoitz (help)
« Reply #4 on: May 24, 2008, 03:17:42 pm »
got all the tools, how much to adujst stud.
Reply #5May 24, 2008, 04:58:22 pm
  • 5104
frig-shnoitz (help)
« Reply #5 on: May 24, 2008, 04:58:22 pm »
i dunno haha i think turning it clock wise makes the boost higher, u gotta experiment with it anyway until u get the boost u want.  its not like ur engine is going to explode if you go above the boost level u want once or twice.
Reply #6May 24, 2008, 05:09:44 pm
smoken u
  • 231
frig-shnoitz (help)
« Reply #6 on: May 24, 2008, 05:09:44 pm »
experimentation is my specialty :twisted:
Reply #7May 25, 2008, 07:05:59 am
mud and diesel
  • 21
frig-shnoitz (help)
« Reply #7 on: May 25, 2008, 07:05:59 am »
Ive got a k14 on my AAZ and i first adjusted my wastegate like that, i was unhappy with the results though, all it does is stop the waste gate opening fully. I found i had boost creep and it felt flat at top end. I cut the metal line to the waste gate and installed a bleed valve. i found this works better with the kkk style of wastegate!
Just my 2p
Reply #8May 25, 2008, 11:53:53 am
smoken u
  • 231
frig-shnoitz (help)
« Reply #8 on: May 25, 2008, 11:53:53 am »
I got mine all adjusted last night, have 20 PSI of boost now!! feels good at top end, still might dial it back down to 15, cause i don;t have any aftermarket studs on my car.
