Author Topic: are my guides to blame  (Read 2353 times)
April 10, 2008, 09:10:05 pm
shegel
  • 312
« on: April 10, 2008, 09:10:05 pm »
i decided to flush my engine today with some seafoam. i poared the whole bottle into the engine. upon startup (it started right away which is odd) it reved higher than usual but not too high and smoked white smoke for a little while. i think that my rings (which is what i thought my blowby was from)may be fine and that my head is to blame. does any of this make sence to you all?
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1April 11, 2008, 03:45:26 pm
shegel
  • 312
« Reply #1 on: April 11, 2008, 03:45:26 pm »
nobody?
Reply #2April 11, 2008, 06:03:04 pm
  • 3255
    • My collection of HOWTOs
« Reply #2 on: April 11, 2008, 06:03:04 pm »
You might get a better response over on the Vortex forums... the magic of Seafoam seems to be more of a Vortex thing ?
Reply #3April 12, 2008, 09:17:23 pm
shegel
  • 312
« Reply #3 on: April 12, 2008, 09:17:23 pm »
more of what my question was....if my guides were bad then could somthing like seafoam(which increases rpms)be a good way to detect faulty guides
Reply #4April 13, 2008, 01:01:37 am
boosted_diesel_84
  • 216
« Reply #4 on: April 13, 2008, 01:01:37 am »
you should to do a cylinder leak down test to see where your problem really is.
-Jack- :D
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #5April 13, 2008, 01:56:39 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: April 13, 2008, 01:56:39 pm »
Seafoam makes a lot of white smoke when used. Once it's all burned out it shouldn't smoke anymore.
91 Passat syncro 1.8T swapped.
Reply #6April 13, 2008, 02:02:34 pm
myke_w
  • 1099
« Reply #6 on: April 13, 2008, 02:02:34 pm »
Guides are generally not to blame for major blowby symptoms, compresion rings (or a worn out bore) are.
It's a good bet that if your rings are shot though, your guides aren't far behind (that is if the engine hasn't ever been apart).
As jack suggested, you really need to do a leak down test to know what the problem is for sure.
