I've got a small amount of diesel dripping from the fuel screw. To fix it I need to remove it, but I know that this screw is very sensitive to any movement. Do I just count how many turns it takes to pull it out or is there an other way to replace the seal? Any help would be greatful.
Thanks, Josh
if the collar is still on thats easy! just back out the whole thing 13mm nut and all! change the "O" ring and put it back in ! easy !!!!
Duane
I've all ready pulled off the collar.
Hey, great idea! Why did'nt I think of that. I guess I'm always tring to make it to technical. Thanks, Josh
Got it!
Fixed in less than ten minutes. No more leaks at this time.
Thanks for the help, Josh
you lucky guy, some of us are pouring faster out the injection pump than they can get it in with the fuel station nozzel...
