Author Topic: Exhaust pipes sizes?????  (Read 2964 times)
January 04, 2008, 04:28:08 pm
haybayian
  • 155
« on: January 04, 2008, 04:28:08 pm »
Yes I know this thread was beaten to death not long ago. I have enjoyed the thread in question but there is something that I did not think of asking. What is the sense of  running a 2.5" (or 3") down pipe when you know that the OEM  catalytic converter own pipe's ID is  1 13/16". I confess that I am rather new to all this and that I am here mostly to learn. However I need to understand what I learn. Could some one elaborate.
Haybayian
Keep it simple if you can.
Reply #1January 04, 2008, 05:07:07 pm
Diesel Fumes
« Reply #1 on: January 04, 2008, 05:07:07 pm »
whats a catalytic converter?   :lol:
Reply #2January 04, 2008, 05:20:30 pm
« Reply #2 on: January 04, 2008, 05:20:30 pm »
Quote from: "Diesel Fumes"
exactly...  :lol:
Reply #3January 04, 2008, 10:30:44 pm
DonGTI
  • 172
« Reply #3 on: January 04, 2008, 10:30:44 pm »
Lucky Baxterds... In the EU they won't pass your car for its VRT/MOT if they don't see a physical cat down the exhaust line...
but a trend has started recently of hammering out the honeycomb inside leaving just the empty bottle  :wink: and for others running the 2-3" pipe helpfull silencer repair shops can empty a catalitic converter, widen its ends, an mount it around a straight pipe... It will fool a casual VRT/MOT inspection if fuelling is adjusted before the test to a more lean mixture...
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #4January 04, 2008, 10:39:56 pm
« Reply #4 on: January 04, 2008, 10:39:56 pm »
There are also high flow cats (get one off a duramax or something)
If you are punching out the guts of the cat I think you are suppose to do it underwater to avoid hazardous particles entering the air/your lungs
Reply #5January 05, 2008, 08:25:48 am
mk2diesel
  • 60
« Reply #5 on: January 05, 2008, 08:25:48 am »
connect a shop vac to the opposite end  you are banging on ... seal with duct tape .....   just platinum and ceramic bits
Reply #6January 05, 2008, 09:33:34 am
« Reply #6 on: January 05, 2008, 09:33:34 am »
Or you could sell it to a scrapyard for some cash, just tell them it's from a car you scrapped
Reply #7January 07, 2008, 05:44:21 am
Jetta Fan
  • 286
« Reply #7 on: January 07, 2008, 05:44:21 am »
I recently cut the cat out of my mkIII (pipe broke right at the cat and so I replaced it with a piece of straight pipe) and you can look right through mine. No honeycomb or anything is visible. Not sure what it is supposed to look like, but can't see how it does anything.
1997 Jetta 1.9TD AAZ
