Loss of power going uphill
Topic: Loss of power going uphill (Read 6118 times)
January 01, 2008, 08:36:38 pm
vegfuel
January 01, 2008, 08:36:38 pm »
So I'm heading back to college in my little Golf n/a enjoying the best ecomony on the road when I start up a huge hill. I stay in 5th of course and seconds later I find that I am petal to the metal and going 40 in 70 zone and in the truck lane. I did a stupid thing and dumped it to 4th and pressed. I looked back and she had a huge tail of black smoke :oops: .
could it be that my pump isn't altitude compensated? Shouldn't I be able to claw up hills? (diesel!)
1986 Golf WVO converted.
January 01, 2008, 08:39:04 pm
vanagonturbo
January 01, 2008, 08:39:04 pm »
Are you sure it was black smoke? Maybe a head gasket problem. What color is the car?
January 01, 2008, 09:05:54 pm
vegfuel
January 01, 2008, 09:05:54 pm »
pretty sure it was black, the car is dark navy blue. It was just black smoke from being under load and going fast.
January 01, 2008, 09:12:54 pm
January 01, 2008, 09:12:54 pm »
I guess one question that needs to be asked is what elevation were you at? An N/A Diesel can loose quite a bit of power at altitude, which would result in black smoke as well.
January 01, 2008, 10:01:18 pm
vegfuel
January 01, 2008, 10:01:18 pm »
Ryegrass Summit elevation: 2535 ft
but it just looses power when climbing. I open it full throttle and I watch the speedometer needle go down.
January 01, 2008, 10:18:16 pm
vanagonturbo
January 01, 2008, 10:18:16 pm »
have you attempted this pass before with different results?
January 01, 2008, 11:04:23 pm
vegfuel
January 01, 2008, 11:04:23 pm »
yes , it has always had this problem
January 02, 2008, 12:06:56 am
ilomax
January 02, 2008, 12:06:56 am »
It sounds like you are going up a hill and your car is "bogging" down.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
January 02, 2008, 04:33:07 am
January 02, 2008, 04:33:07 am »
sorry to say man but its your N/A. either get a Giles pump, or a turbo :twisted: (or both :twisted: :twisted:)
once the turbo engine is at 3500 rpm and boosting fully, its virtually impossible for them to 'slow down' unless loaded down considerably. mine will have no problems past those rpm's. it'll even accelerate a bit or a lot depending on my foot position :wink: it's the turbo that helps these engines 'claw' up hills
also not to scare you or anything, but try to keep the smoke down while going uphill... or you may find yourself with a blown HG... your best bet is to just tough it out in 4th gear running about 3500 rpm and trying to hold a speed with as little smoke as possible.
January 02, 2008, 05:28:14 am
subsonic
January 02, 2008, 05:28:14 am »
What trans do you have? Diff ratio?
January 02, 2008, 06:04:25 am
wikdslo
January 02, 2008, 06:04:25 am »
Welcome to the world of 52 hp
Try throwing some of your cargo out the window next time. That should help lighten things up !
Reply #11
January 02, 2008, 10:22:27 am
vegfuel
Reply #11 on:
January 02, 2008, 10:22:27 am »
Quote from: "subsonic"
I just know that it is a five speed. Should I check the number on the bell-housing at sciroccogears.org or whatever?
Thanks for the imput
. I think I will just stick with my stock n/a for now. If I do mods to it I think I might run into more problems like heat issues.
What I really want to do is find a low miles TDI or GTD engine to drop in it :wink:
Reply #12
January 02, 2008, 10:48:28 am
shegel
Reply #12 on:
January 02, 2008, 10:48:28 am »
dude i have the same problem...i go from sea level to 800 feet over the coarse of about 2 miles. if i hit the botttom of the hill at around 70 im at about 40-45 at the top. i thought it was because i have a car that was previously neglected by the po. but maybe not. 86 golf 1.6 mech with the 5 spd trans......=.......life in the slow lane. :roll:
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #13
January 02, 2008, 12:29:55 pm
bert
Reply #13 on:
January 02, 2008, 12:29:55 pm »
Your lucky it wasnt in a mercedes 2.4D W123 man you would have been in 2nd :? drove one round france,slowly,got upto 80 on the flat,TINY hill and watch the speedo drop,really should have brought a 300D W123
Bert
Reply #14
January 02, 2008, 05:15:17 pm
lyeinyoureye
Reply #14 on:
January 02, 2008, 05:15:17 pm »
With ~50hp, it's all about gearing.
