Author Topic: My Mk1 1.6TD build...lots of pics  (Read 23580 times)
Reply #30November 17, 2007, 02:48:21 am
Fionn
  • 24
« Reply #30 on: November 17, 2007, 02:48:21 am »
Where did you pick up the braided oil and coolant lines, or did you have them made up?
Reply #31November 17, 2007, 05:02:43 pm
Greasecar
  • 126
    • http://www.greasecar.com
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #32November 17, 2007, 07:29:54 pm
cowboybootlegger
  • 26
« Reply #32 on: November 17, 2007, 07:29:54 pm »
Quote from: "Fionn"
I had them made to spec by a hydraulic hose shop, they were about $40 each.   They're teflon, have a pressure rating of 1500psi and temp rating of 400 degrees.   Most hydraulic shops will make you just about any hose or line you need while you wait.  They can use a fairly wide variety of fittings as well.
Reply #33November 18, 2007, 12:29:26 am
Fionn
  • 24
« Reply #33 on: November 18, 2007, 12:29:26 am »
Thanks a million, will look into getting them made locally then.
Reply #34November 26, 2007, 02:24:00 pm
Baxter
« Reply #34 on: November 26, 2007, 02:24:00 pm »
These Stickers are ready.
There isn't loads of them.
CowboyBootlegger, can you drop me a PM so I can send your freebies.
Thanks for the help.
Simon. 8)
