Author Topic: Aligning spline on throttle assembly  (Read 3533 times)
October 30, 2007, 06:10:22 am
regcheeseman
  • 714
« on: October 30, 2007, 06:10:22 am »
Like a idiot I forgot to mark the spline position on the throttle assembly as I took it apart to do the governor mod.
Can anyone help - is there a baseline setup?
Reply #1October 30, 2007, 07:11:03 am
  • 3255
    • My collection of HOWTOs
Re: Aligning spline on throttle assembly
« Reply #1 on: October 30, 2007, 07:11:03 am »
Quote from: "regcheeseman"
Nope.... trial and error are your friends now... !
Reply #2October 30, 2007, 03:55:11 pm
Baxter
« Reply #2 on: October 30, 2007, 03:55:11 pm »
About 10 threads down from this one!
http://vwdiesel.net/phpBB/viewtopic.php?t=10754
Reply #3October 30, 2007, 04:47:04 pm
rallydiesel
  • 1880
« Reply #3 on: October 30, 2007, 04:47:04 pm »
With the pump top on and throttle arm off, rotate the shaft with a screwdriver. You can get an idea of the max and zero throttle positions this way and place the arm on accordingly. It's pretty straight-forward once you know how far the shaft rotates in either direction.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4December 05, 2007, 12:56:12 pm
regcheeseman
  • 714
« Reply #4 on: December 05, 2007, 12:56:12 pm »
If I get the throttle arm on roughly in the correct position, can I adjust the two screws (max and min stops) to get back to factory settings or would it be better to keep refittin the throttle arm until it's right. It's a bit tricky to get that top spring on, though I guess I could omit the spring until I'd found the right spline position?
Reply #5December 05, 2007, 04:26:28 pm
  • 3255
« Reply #5 on: December 05, 2007, 04:26:28 pm »
My vote would be to omit the spring and get the orientation right, then mark it and reassemble with the (damn) springs.
I don't think playing with the min/max screws will give you the best end result.... but I've never tried it personally.
