Boost Controller (homemade or aftermarket) vs other mods
Topic: Boost Controller (homemade or aftermarket) vs other mods (Read 12192 times)
May 28, 2004, 08:04:10 am
n_tensetuning
User+
May 28, 2004, 08:04:10 am »
hey guys,
Just wanted to get another thread going.... this time on boost controllers.... homemade or aftermarket and see what everyone is running
i think this would be a much better way/safer way to up the boost on our motors, than doing the old removal of the pressure regulatiing valve on the intake manifold, or modding the wastegate lever... or removing the line from the compressor side of the turbo to the wastegate
anyone??
david
81 vw caddy 1.6td
May 28, 2004, 09:54:29 am
VWRacer
May 28, 2004, 09:54:29 am »
David,
Here is a scan of the gated boost controller I recently purchased off eBay ($14 delivered). You can see that the price stickers from the hardware store are still on it...
It was worth the $14 for me not to have to spend half a day running around to different hardware stores finding all the right pieces.
I prefer a gated controller over a bleed-type (aquarium bleeder) controller. The bleed-types bleed off boost all the time, while the gated type allows full boost all the time until reaching its release pressure, at which it opens like a mini wastegate to hold that pressure. That ball is 8mm, too, which is at least as large as the ID of the pressure line opening the wastegate, so it can never act as an in-line restriction. A bleed controller, OTOH, cannot release sudden surges of pressure as well, and are more prone to boost creep.
A line from the turbo compressor or intake manifold is run to the barb at left in the photo, then a line runs from the barb at bottom to the wastegate. Dead simple, ultra reliable and tunable, and super cheap. My kind of performance parts!
Edit: Here's link to a current eBay auction from the guy I bought mine from ...
Boost Controller
Disclaimer: I don't have any fiduciary interest in the seller or product -- just offering info.
Stan
C-Sports Racer
May 28, 2004, 10:06:33 am
n_tensetuning
User+
May 28, 2004, 10:06:33 am »
is it adjustable.... how much boost can you run with this?
i'm running 10psi right now off an 1.6td off an 85jetta 1.6td
the motor is in my 81 vw pickup
is the screw adjustable/tuneable? can you lower or up the boost with this?
thanks for all your info+help
d
81 vw caddy 1.6td
May 28, 2004, 10:17:41 am
Dr. Diesel
Authorized Vendor
May 28, 2004, 10:17:41 am »
I tried that same unit off ebay, and found it to be utter crap!
May 28, 2004, 10:18:00 am
DieselsRcool
May 28, 2004, 10:18:00 am »
VWRacer
Can you post the ebay item# so we can contact the guy making them?
May 28, 2004, 10:20:09 am
Dr. Diesel
Authorized Vendor
May 28, 2004, 10:20:09 am »
save yourselves the hassle. don't bother with that thing.
(sorry stan!)
May 28, 2004, 10:25:12 am
VWRacer
May 28, 2004, 10:25:12 am »
Yes, the controller is adjustable. That's the point of the bolt and lock-nut. To raise the boost one screws in the bolt, adding spring pressure against the ball, which blocks the pressure line from the turbo. More spring pressure means more boost before the air pushes the ball back against the spring and opens the wastegate.
I don't know how much boost this particular spring can hold, but I am guessing that it's at least 20-25 psi. I'll do some testing later and post the results. Gotta run for now.
Stan
C-Sports Racer
May 28, 2004, 10:28:17 am
VWRacer
May 28, 2004, 10:28:17 am »
Ah, I see that others have now weighed in...
Since I am only running 12 psi of boost, I have not yet tried this controller. Dr Diesel offered us a diagram for making an effective one, so now I'm hoping he posts it soon, 'cuz I sure intend to run more boost in the near future!
Stan
C-Sports Racer
May 28, 2004, 10:29:48 am
DieselsRcool
May 28, 2004, 10:29:48 am »
Hey Doc!
What yave you found to work best? Do tell!
May 29, 2004, 10:23:32 am
Dr. Diesel
Authorized Vendor
May 29, 2004, 10:23:32 am »
I made an inexpensive, fully adjustable, gated electro-mechanical boost controller. So far, it's perfectly reliable and accurate up to 30 psi. Have to wait for the new engine to try beyond that level. I'll have details soon.
May 29, 2004, 07:20:55 pm
chris-pl
User+
May 29, 2004, 07:20:55 pm »
I am using mechanical boost controller from turbosmart
http://www.turbosmart.com.au/
so far it is working ok.cost 80$ can with tax .
:oops:
Reply #11
May 29, 2004, 07:38:47 pm
AntonUK
Reply #11 on:
May 29, 2004, 07:38:47 pm »
i bought a similar item on ebay:
But my controller has a small hole on the elbow where the output to the wastgate is. does anyone know if its supposed to be there?? Iv not used the controller yet so i dont know if its going to work or not. It puzzles me since the pressure will be escaping through the hole (like a bleed valve) but its not adjustable. It looks like its been drilled with a small drill bit. Iv tride to contact the seller but havnt heard anything from him! :x
cheers guys.
Reply #12
May 29, 2004, 09:42:00 pm
DieselsRcool
Reply #12 on:
May 29, 2004, 09:42:00 pm »
The controller also acts like a check valve. This small hole lets the air back out of the waste gate after the pressure drops as the air cannot return through the valve. Otherwise once the waste gate opens it would stay open.
Reply #13
May 30, 2004, 07:02:15 am
AntonUK
Reply #13 on:
May 30, 2004, 07:02:15 am »
ahh I see, thanks for clearing that up with me.
