Author Topic: Breaking break lines...loose  (Read 5411 times)
September 16, 2007, 08:00:42 am
Trimster
  • 74
« on: September 16, 2007, 08:00:42 am »
My org. breaklines are getting scary so I have a new set of SS lines on the bench. The connections on the old ones are way tight/stuck. Ideas on how to break these babies loose without breaking/rounding off the old fittings?
Bob
'83 Caddy, 1.6 NA Diesel, 5 speed, AC
2- motorcycles, 36' 5th wheel, sailboat, RC airplanes... to many interests, not enough time.
Reply #1September 16, 2007, 08:02:46 am
« Reply #1 on: September 16, 2007, 08:02:46 am »
vise grips
Reply #2September 16, 2007, 02:07:17 pm
BlackTieTD
  • 1512
« Reply #2 on: September 16, 2007, 02:07:17 pm »
tap them nice with a hammer, spray some pb blaster on them and tap them some more and repeat if you'd like. then try to loosen them the next day after you hit them with the pb blaster again. vice grips for sure if they are rounding off.
Reply #3September 17, 2007, 03:22:12 am
bvolks73
  • 183
« Reply #3 on: September 17, 2007, 03:22:12 am »
If I'm replacing the steel lines and it doesn't look like they're going to come apart easily I just cut the line so I can use a 6 point 11mm socket on it.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #4September 17, 2007, 04:25:08 am
somolovitch3
  • 290
« Reply #4 on: September 17, 2007, 04:25:08 am »
A set of tubing wrenchs comes in handy.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #5September 17, 2007, 05:39:17 am
FineFrank
  • 72
Brake Lines
« Reply #5 on: September 17, 2007, 05:39:17 am »
I use a propane torch to heat up the nut (the line usually gets hot, too) and let it cool. If the tubing wrench begins to round off the nut, I stop and use vise grips.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #6September 17, 2007, 09:26:05 am
« Reply #6 on: September 17, 2007, 09:26:05 am »
If I'm replacing the line I usually just start with vise grips. New fittings are less then $0.50 each so I always replace them.
Reply #7September 21, 2007, 05:46:07 pm
Trimster
  • 74
« Reply #7 on: September 21, 2007, 05:46:07 pm »
Ok.... it's stuck so hard that the vice grips have ground the 11 mm side to nothing left to grab on to. I tried my mini-tourch... no help.  If I cut the metal tubing side of the line, I still can't get the fitting apart so I can reuse the line mount on the inner side of the wheel well.  It's always amazed me that this part of the breaking system(s) are so poorly designed and it remains decades later.
I'm not sure what to do now. I have the same problem with all 4 lines.
bob
Bob
Reply #8September 23, 2007, 04:30:09 pm
BlackTieTD
  • 1512
« Reply #8 on: September 23, 2007, 04:30:09 pm »
did u try the pb blaster and tapping them with a hammer?
Reply #9September 23, 2007, 05:08:01 pm
Trimster
  • 74
« Reply #9 on: September 23, 2007, 05:08:01 pm »
So job done.  PB stuff and tapping with hammer led to mini torch and vice grips which lead to Dremmel and cutoff wheel.  I just cut them off, got new fittings and reflaired the tubing. 34 yrs of stuck-together just was not going to come apart.
Thanks all for the input. Nice stainless lines now gleam in the wheel wells.
Bob
Reply #10September 24, 2007, 08:25:31 am
BlackTieTD
  • 1512
« Reply #10 on: September 24, 2007, 08:25:31 am »
wow never had to go that far personally and we get salted hard up here in the winter. SALT lake is right! glad it worked out  :mrgreen:
